08-20-2019
10:35
13:47
08-20-2019
10:35
13:47
Since our responses get lost and honestly Everyone is just freaking out right now. I would like to tell you what worked for me.
It took 3 tries for my update to install. I found out later it would have installed faster had I plugged into my computer. I did end up removing my device from Bluetooth and then reconnecting it. It did take again 3 tries.
I initially had major problems. Steps will disappearing, my device was very warm like it was overheating, I had to charge 3 times in one day, etc. I keep hearing how you could reboot your device but I didn't understand why I couldn't get it to work.
I did the following.
1) Remove from Bluetooth (not disconnect, remove)
2) Logout of fitbit app. Then I deleted the app and reinstalled the app. ( DO NOT LOG IN)
3) charge your device.
4) reboot your device. Make sure you are actually holding the button on till it reboots. This was my mistake.
5) connect your device to Bluetooth. Remember you have to follow the instructions of adding a new device. (Make sure it's discoverable, etc)
6) login to the app
This is what solved the issue for my device and my mom's device.
09-24-2020 16:48
09-24-2020 16:48
I just recently started having the same problem with my Charge 2. I tried the steps listed in the original post and it worked. I did plug the fitbit into my computer instead of an outlet. I don't know if that made a difference, but other posts suggested that it does. Hopefully, the fix will last.
