Hi, welcome to the Community forums @depaor8 !
Thank you for your inquiry about the Charge 4.
You'll be able to change the brightness of the screen by going to the settings app on your device. Please follow the steps listed here below:
In addition, make sure the DND (Do Not Disturb Mode) and the Sleep mode are also turned off, as they automatically dim the screen. You can find these options by pressing and holding the side button for about two seconds until the Quick Settings screen appears.
Have a great day.
If your Charge 2 display is dim, I'd recommend restarting your Charge 2 by following these steps: Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger. Clip the other end of the charging cable to the port on the back of the tracker.
Regards,
Will
