12-05-2018
07:36
14:34
12-05-2018
07:36
14:34
The screen on my Fitbit charge 3 froze yesterday, I tried trouble shooting it myself with no luck. I ended up contacting tech support and got no new information. He kept trying to have me to re-start the device but it was so locked up I couldn't get it to turn off/re-set. The gentlemen I spoke with said he has turned my "case" over to a higher up and told me to check my e-mail for a response/the next step. After trying to look up some more today of how to fix it I finally found something that actually helped. I went into the app on my phone and changed my clock face. As I tried to change it the Fitbit screen lit up saying there was an error trying to change it but then it unlocked it and changed the clock face. I went back in and changed it back to the one I wanted and it seems to be ok for now. I Just thought someone else might get a helpful tip from this!
Thanks for posting your solution, @sunflwrgirl, and welcome to the forums! Others have reported experiencing problems with various clocks causing similar problems, so your post will help others.
Best AnswerWhile the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable.
Regards,
Will
