10-14-2022
07:01
03:52
10-14-2022
07:01
03:52
My Charge 3 just started with a charging issue; it looks like one of the charging contacts is off center or at least is duller than the other two. Are there any fixes for this? Does it need to be cleaned?
Hi there, @ZaxPower. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Charge 3. @MakMak @willjoe Thanks for helping out! 🙂
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
See you around.
Best AnswerHi, @ZaxPower! You could try shifting it back into place, but I believe a lot of people have experienced this issue and the solution is usually to replace the charging cable.
MakMak | Community Council
Dust and debris can accumulate over time. Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device? The USB port or outlet is faulty. Try a different USB port or a UL-certified wall charger.
Regards,
Will
See you around.
