My Fitbit Charge 2 was not connecting or even syncing with my Pixel3a. Previously worked with no issues. Then I performed a factory reset on my phone.
Syncing totally froze.
All permissions are on. Bluetooth is on. I turned Bluetooth off and on again, unpaired my Charge 2 from my Fitbit account and attempted to repair. I uninstalled and reinstalled the Fitbit app. I did a soft reset of my Fitbit device. I tried (unsuccessfully) to do a factory reset.
THEN I downloaded the Fitbit app on a secondary device (old iPad) and managed to successfully pair and sync my Fitbit device with the iPad. I unpaired my Fitbit device from the iPad and then repaired it with my android. At last! Syncing issue resolved! My best guess: FItbit, whatever your last update/security patch did sucks.
Hopefully this information will be helpful to anyone else with similar issues.
I've tried multiple trackers and they won't sync to my Pixel3a or ipad mini2. My Charge 2, an old flex and a flex 2. Each would be "found" by the apps but then wouldn't connect.
I'm going to try a reinstall of the fitbit app on my ipad and see what happens....
Best AnswerI had the same issue, Charge 2 had not synced to my Pixel 2 since Nov 9. I had tried all of Fitbit's recommendations: restarting it, reinstalling the app, turning Bluetooth off and on, etc. But what finally fixed it was syncing to my husband's phone. My phone's app then immediately started syncing.
