09-29-2016 19:53 - last edited on 09-09-2020 10:26 by MatthewFitbit
04-20-2017 07:30
04-20-2017 07:30
@Nakul wrote:I have been facing the same issue. Got my Charge 2 couple of days back, I usually run for 3 miles according to my treadmill, but fitbit shows I ran 4.8 miles and took 9677 steps which I believe is wayyyyyyyyyyyy off. I don't think this data is accurate and I wouldn't recommend this product to anyone.
That's 2016 steps per mile which is reasonable for running. Usually, I do 2,130 steps per mile while walking.
Any pedometer is only as accurate as the stride length you set. I find the Charge 2 is extremely accurate in counting steps while walking or jogging. The way I know this is I often use a metronome. The exception would be if you put your hand on the rail of the treadmill or are pushing a shopping cart.
04-20-2017 10:44
04-20-2017 10:44
@Nakul when it comes to distance on a treadmill it is calculated based on the stride which will need to be setup for the speed of the run.
As for the step count, have you done any tests yet? Simply put the tracker into its run mode, then start running while counting the steps yourself. I count every left fott and then multiply by 2
04-20-2017 14:37
04-20-2017 14:37
I was on my laptop sending mails, didn't move for two hours but the surprisingly according to Fitbit I moved 672 steps. Same thing happened last night, was driving back from work and after sitting in car for 45 mins and doing nothing, I had already taken 840 steps. It is counting steps for no reason and the data is highly inaccurate. I'm at 10000+ steps today but I can bet the data is at least 3000 steps more than it should so I stand by my verdict, Fitbit Charge 2 is a waste of money and time. I'm highly dissatisfied with its performance.
04-20-2017 15:11
04-20-2017 15:11
I suggest you go to the settings and indicate you are wearing the Fitbit on your dominant hand.
04-21-2017 07:56
04-21-2017 07:56
@Nakul setting the tracker for dominant hand, even if on the non-dom arm will help.
When it vomes to the tracker, which is on the arm and looking at arm motions, there will be times when a repetitive motion may be interpreted as steps. This is just the nature of any step counter.
Fitbit does give us a way to remove this data, and here is three articles i think will help http://help.fitbit.com/?q=Drive
Also if you have an atduino phone, there are apps to automate the logging of a drive. Drivebit and Travelbit
05-29-2017 21:40
05-29-2017 21:40
Hello,
I have read the details on accuracy but for mine it's far too sensitive. I've only had it 2 days and reckons I've done 1413 steps since midnight (it's now 05:36am and I'm sat in an office). I saw it record over 50 steps just for me going to the loo (as in not steps to and from - steps whilst actually in the loo and then re-dressing myself!) Can the sensitivity be changed at all because if I cannot change it or be able to have the steps counted more accurately then I'll likely be sending it back which is a shame as it was an early gift for my birthday.
Plus my tracker doesn't seem to be syncing up 100% from the app, I'm making settings via the computer or app which aren't appearing on the tracker. i have the Charge 2.
06-02-2017 04:11
06-02-2017 04:11
In my case, Charge2 add more than twice the steps that I actually do and it seems to me that it counts every single movement I do, not only the steps, but also it counts my arm movement, my hand movement, also I noticed that it counts steps while I stay at my place with no movement at all. This actually gives me fake figures and impact negatively on the other given figures such as number of burnt calories and activity. I lost my trust in this product as it is useless now to me.
06-02-2017 07:22
06-02-2017 07:22
06-03-2017 15:00
06-03-2017 15:00
Hi Ronda,
Can you please tell me how many steps being added on top of your actual number of steps that you do per day after you adjusted the setting and marked that you wear it on the dominate hand?
I am asking because I followed the same advice and changed the setting and selected that I wear it on the dominant hand but I still see additional hundreds of steps are added to my actual number of the dialy steps.
Regards,
06-03-2017 15:19
06-03-2017 15:19
I set my stride length to 10 inches (crazy!) and the Fitbit Charge 2 still misses over 50% of my steps. So disappointed and depressed about this. It is so demotivating to walk 2-3k steps and Fitbit only records a couple hundred... 😞 Bummer! I am rooting for you guys, but I am already looking for a competitive solution. Hope you can fix this soon, but it seems like an issue for over a year.
07-08-2017 07:07
07-08-2017 07:07
The same exact thing happened to me @Qzie, just got my charge 2 yesterday and noticed at the end of the day my steps were off....this morning I reset the charge 2 and went for about a half mile walk....it counted only 158 steps??? What the heck? I guess there has been no solutions? This so disappointing, I've been a fitbit user for over 3 years, starting with the one and then the charge HR....looks like it might be time to switch to Garmin?
07-08-2017 11:40
07-08-2017 11:40
07-19-2017 09:38
07-19-2017 09:38
If you are primarily concerned with steps, you may want to wear a fitbit zip. I clip mine to my bra. But it does not have a heart rate monitor. You can wear it with your watch for Information on both hr and steps or consider pairing it with a more accurate chest strap heart monitor.
07-19-2017 14:27
07-19-2017 14:27
07-19-2017 14:33
07-19-2017 14:33
No offense. But whether we should or shouldn't have to do that is irrelevant. The question was how to get the most accurate step count while wearing a "wrist"pedometer and walking without moving your wrist. I think to expect a pedometer to count steps without motion is a little unrealistic.
07-20-2017 06:22
07-20-2017 06:22
07-20-2017 07:11
07-20-2017 07:11
07-20-2017 09:08
07-20-2017 09:08
You should reread what you write before you post it lol. You just stated that you believe a pedometer should count steps without moving. You also said putting a tracker on a body that bounces while walking can be compared to an immobile wrist. And why would a woman need to shake their boobs when their body is already bouncing from the movement?? That is just illogical. We should really concider physics and the distribution of pressure and resistance that the pedometer registers. And how that fact that potential energy substantially diminishes when traveling from the feet to the outer appendages. A great deal of energy is absorbed into the muscles and bones and now you're adding the inactivity of the limbs. Let's be honest: you don't want a solution; you just want to complain. You are trolling.
07-20-2017 14:16
07-20-2017 14:16
07-20-2017 14:38
07-20-2017 14:38
I love your reply. I agree with you 100%. I can't believe some people think we shouldn't expect are charge 2 to work they way it is advertised.
