11-24-2018
00:51
18:22
11-24-2018
00:51
18:22
Hi I'm having the same problem. The Fitbit charge 2 ran out of battery on Thursday morning. I charged it from Thursday lunchtime through to Friday afternoon. I put it on my wrist on Friday afternoon and went for a long walk, it's not recorded any steps at all. The screen doesn't light up to show the time when i flick my wrist as usual. When i press the button I on the side screen changes are really reallllly slow. The device isn't responding when I tap the screen. The green lights on the back are flashing at about half the speed they usually do. The device is fully charged and I've updated the app. The device hasn't been wet. I've restarted it 5 times and that hasn't resolved the issue. Any ideas or suggestions?
Hello @JakiWatt, have a warm welcome to the Fitbit Community. ![]()
I appreciate your participation in the Forums, for having shared your experience with us and for also like to thank you for letting us know you've already restarted your Charge 2. I have moved your post from the Charge board to the Charge 2 board to keep our Forums organized.
At this moment, I would like to suggest you to set up your tracker as a new device to reset the connection with your phone and to remove any glitches affecting your tracker. Don't worry, none of the information already stored in your account will be deleted.
To set up your tracker as a new device:
I hope this can be helpful, if there's anything else we can do for you, please feel free to reply.
I tried the above and it still doesn't work. It keeps searching but not locating Charge 2. For some reason when I charged it the other day, the charge didn't hold. My time is stuck to this morning when battery died. I restarted phone, bluetooth and deleted the Charge 2 that was connected with it to re -do. Still nada. Help!!!
Best AnswerI have exactly the same problem. It started about four days ago, and I can not find any solution either. The suggestion provided does not work.
