07-15-2019
12:02
14:41
07-15-2019
12:02
14:41
My charger rarely works unless I keep pressure on it
07-16-2019 09:53
07-16-2019 09:53
@Doug1954, welcome! It's good that the community is growing!
Let me help you with your Charge 2 charging cable not working correctly. Try cleaning the contacts on both the tracker and the charging cable using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Let me know how it goes.
