07-19-2019
08:19
14:41
07-19-2019
08:19
14:41
My charge 2 keeps turning notifications off and on and thats it... but if i hold the button down it stops ..so i got a tiny cable tie and put it around the fitbit so its stopped buzzing and i can see the screen ... i may have to do this everyday untill someone can come up with a proper fix for this have not tried charging it with it on
07-22-2019
08:50
09:04
07-22-2019
08:50
09:04
@Spoonicus1, welcome! It's good that the community is growing! Sorry for the delay in my reply.
Let me help you with your unresponsive Charge 2. You can clean the button area with cotton and rubbing alcohol. After this use compressed air at a distance to clear the area. Finally restart your device.
Let me know how it goes.
Best Answer07-22-2019 12:14
07-22-2019 12:14
Best Answer07-25-2019 06:17
07-25-2019 06:17
Had to keep the button pushed in for it to work then it decided to working but then the battery decided to last 20 minutes and now it is pretty much dead
Best Answer01-02-2021 09:32
01-02-2021 09:32
I did try cleaning it but i think it had just given up ..I got a new fitbit in the end
Best Answer10-31-2022 09:45
10-31-2022 09:45
Mine is doing same thing. These are junk. Poorly built and very poor support. I feel taken to the cleaners.
Best Answer12-07-2022 15:44
12-07-2022 15:44
Cold day in Hell when I buy another one of these **ahem**. Screw me once your fault. Screw me twice, my fault. Never happen!!!
