03-03-2019
02:35
17:14
03-03-2019
02:35
17:14
Fitbit is logging floors, 10 already today, and I have been on flat surface 🤔
03-03-2019
13:13
10:43
AlvaroFitbit
03-03-2019
13:13
10:43
AlvaroFitbit
Wind and cold can effect floors. It adds no calorie burn
You can remove them if you want
I found it to be more of a hassle so I just ignore them
Wendy | CA | Moto G6 Android
13:13
10:43
AlvaroFitbit
03-03-2019
13:13
10:43
AlvaroFitbit
@Mandy_Tarpey Sorry to hear that your Charge 2 is counting steps. Adding to @WendyB 's explanation your device uses it's altimeter to detect variance in altitude. It will count 1 floor for every 10 ft it detects you climbed. There are situations that may affect the floor count like stormy weather (that has an actual impact on atmospheric pressure), gusts of wind, an AC unit in a closed room or opening a door. I suggest you start by cleaning the back of the device with cotton and rubbing alcohol then use compressed air at a distance to clear the altimeter's opening (check the image for reference). Finally restart it.
Let me know how it goes.
