11-13-2020
02:31
06:36
AndreaFitbit
11-13-2020
02:31
06:36
AndreaFitbit
Hi, my Charge 2 no longer records my sleep. I have tried to reset but it will not reset. Does anyone have any suggestions?
Thanks
11-18-2020 06:40
11-18-2020 06:40
Thanks for getting back to us @MicheleGr. I'll be glad to assist with your sleep record inquiry.
Since your Charge 2 isn't registering your sleep, I recommend trying the following:
If your tracker is registering your sleep but not providing you with sleep stages, take into consideration the steps in the help article Why don't I see sleep stages today?. I also suggest checking if your Fitbit app is updated.
Let me know the outcome.
Best Answer11-18-2020 07:37
11-18-2020 07:37
Hi, thanks for the advice. I am aware my Fitbit is not up to date. When the charger is connected and the battery is full, when I press the button, nothing happens
Best Answer11-18-2020 09:04
11-18-2020 09:04
Thanks for getting back to us @MicheleGr. I'll be happy to continue assisting you.
Does your Charge 2 turn ON when it's not connected to the charging cable? Is it working at all?
I'll be waiting for your reply and keep on visiting the forums.
