Charge 2 doesn't sync properly
FitBits not syncing problem goes back at least as far as 2016, but STILL not fix.
This is lame, and I have to call out the development team. You don't just write an article how to workaround a bug, and leave it unfixed for years, instead you fix the bug. I'm afraid your approach is not professional. That's a fact.
1 REPLY 1
@FitterEveryDay I hope you're doing well!
Sorry to hear about your syncing issues. Lets try refreshing the link between your phone and your tracker by doing the following:
  1. Go to your phone's bluetooth settings and remove all devices listed there.
  2. Restart your phone and restart your device
  3. Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  4. Also, on an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  5. You can find troubleshooting instructions here.
Let me know how it goes.
Alvaro | Community Moderator
