06-15-2022 14:29
06-15-2022 14:29
My Charge 2 battery was unexpectedly dead this morning, and after charging it, it has become unusable. First it just kept cycling quickly through all the different modes, then it was vibrating with notification alerts for several minutes. Now it's just frozen with a heart on the screen. Is it done?
06-16-2022 05:36
06-16-2022 05:36
@alicat003 The rechargeable battery in a Fitbit does have a lifespan. With average use, they have a lifespan of 3-5 years. The Charge 2 was released in 2016, the year you joined. You need to prepare yourself for the possibility that your Fitbit is coming to the end of its life, especially when you say your Fitbit was unexpectedly dead. Based on user posts, users of all devices from that time (Alta/Alta HR, Blaze, and Charge 2) are having the same experience as you.
Laurie | Maryland
Best Answer06-15-2022 17:00
06-15-2022 17:00
Hello @alicat003
I’d try restarting your Charge 2: https://help.fitbit.com/articles/en_US/Help_article/1186.htm. If the problem continues you can try changing the clock face through the the Fitbit App : https://help.fitbit.com/articles/en_US/Help_article/2311.htm
I’ve seen changing the clock face help some. Preferably with one made by Fitbit.
I hope this helps
06-16-2022 04:07
06-16-2022 04:07
Restarting it seems to have done the trick. Thank you, MegaBite!
06-16-2022 05:32
06-16-2022 05:32
That’s great news @alicat003! 😃 I’m happy it worked and your up and running again. Enjoy the rest of your day and Happy Stepping!
06-16-2022 05:36
06-16-2022 05:36
Laurie | Maryland
Best Answer06-16-2022 06:03
06-16-2022 06:03
I think you're right...I thought it was okay after the restart but it started acting wonky again. 😞 I didn't realize that I've had it that long!
Best Answer06-16-2022 06:07 - edited 06-16-2022 06:08
Hello again @alicat003
You can certainly try restarting it again. It certainly wouldn’t hurt to try. Hopefully it might help. Did you try changing the clock face as well? But yes…all batteries in Fitbit Trackers do eventually die. It’s to be expected since you’ve had it for so long.
Best Answer06-16-2022 06:27
06-16-2022 06:27
06-16-2022 06:32
06-16-2022 06:32
😃 it lived a long life for sure @alicat003! Enjoy shopping and I hope you really like the new tracker you pick
