10-26-2019
05:53
12:06
10-26-2019
05:53
12:06
I put my Fitbit on charge and now it won’t come on . The screen is blank. Not sure what to try
10-26-2019
07:26
08:43
AlvaroFitbit
10-26-2019
07:26
08:43
AlvaroFitbit
Try a Restart and do it several times if necessary.
08:45
14:00
10-28-2019
08:45
14:00
@Sarah0000 Welcome! It's nice to have you on board! Sorry for the delay in my reply.
Let me help you with your unresponsive Charge 2. Do you see if your tracker is charging. If you don't see and reaction when you plug it then try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL listed usb wall adapter. Also try the restart suggested by @SunsetRunner.
Let me know how it goes.
Best AnswerI'm having the same issue with my charge 2. I charged it and got a bunch of lines. I tried resetting and now the screen is just blank. Help!
