02-12-2020
05:19
10:23
02-12-2020
05:19
10:23
I have loved my Fitbit Charge 2, but it recently has completely stopped notifying me of receiving text messages. For a while it was still notifying me of phone calls, but now it has also stopped doing that.
I have tried turning off Bluetooth, reconnecting and even allowing the Fitbit to completely die, but have found no solution. I know the vibrate still works, because the silent alarms still function properly.
Is it common for parts of the device to just stop working?
02-13-2020 07:58
02-13-2020 07:58
@KDbird21 Welcome! Thanks for being part of our Community!
Let me help you with your Charge 2 not getting notifications and thank you for troubleshooting this issue. Which phone are you using? Is it compatible? You can try the following:
Let me know how it goes.
Best Answer02-26-2020 18:37
02-26-2020 18:37
Thanks AlvaroFitbit for helping me troubleshoot. I have a iPhone7 and have updated my software to the most recent available. I have also updated the app but neither has resolved the problem.
I checked the battery saving mode, but it was not active. And I have tried restarting both my phone and the device, but neither resolved the issue. I also tried deleting all saved devices from my Bluetooth and re-finding them. I might be doing these things incorrectly, but nothing I have tried has worked. are there any other possible things I could try? Do you recommend a place/store that might help me troubleshoot?
02-26-2020 23:37
02-26-2020 23:37
Hi There , I have an iPhone 7 latest software and charge 2 latest software and I have tried the options you said and it’s still not working, I am not the only one as some of my friends on android are having issues too
Best Answer02-27-2020 10:50
02-27-2020 10:50
It has been months since it worked, still waiting. Done everything suggested, it just doesn’t work 🤬
Best Answer09-09-2020 10:06
09-09-2020 10:06
I have the same problem, suggestions did not work. Is it that the Charger 2 is too old, everything else works!!
