01-11-2019
07:09
17:54
01-11-2019
07:09
17:54
2 green lights flash on connecting to power but not charging
is synced ok but telling battery empty
01-13-2019
09:41
10:31
01-13-2019
09:41
10:31
@Norma48 Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your Charge 2 isn't charging. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Let me know how it goes!
Best AnswerI did what you said by cleaning it
on my app it says fully charged and synced
when plugged in battery showing empty
when unplugged no response at all blank screen
08:21
10:31
01-15-2019
08:21
10:31
@Norma48 thank you for the update. Since this didn't work please let our Support team know so they can further assist you. You will get an email from them.
