04-07-2019
09:05
16:45
04-07-2019
09:05
16:45
My Fitbit Charge 2 Is Not Charging Properly On The Charger That I Got With It. So I Was Wondering If It Is Possible To Get Something Else To Charge My Fitbit Charge 2 Properly.
@SunsetRunner Welcome! Thanks for being part of our Community!
I will gladly assist you with your Charge 2 that isn't charging. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Let me know how it goes.
