04-30-2019
02:14
16:26
04-30-2019
02:14
16:26
Help!! My charge 2 stopped syncing 2 weeks ago. Now I can't get it to pair with my Samsung J6 again. Have uninstalled the app and reset my watch. Nothing works.....
04-30-2019 13:38
04-30-2019 13:38
Hello @NicksNix is the a charge 2 still connected to your Fitbit Account. You don't say anything about removing it.
Did you remove the Charge 2 from your phone's bluetooth? This odd the way to un-pair the tracker.
What so you mean by reset the watch?
04-30-2019 23:24
04-30-2019 23:24
Thank you for the reply. My fitbit stopped syncing on the 17th. I removed the app from my phone, and re-installed it. my account is still active, but my fitbit is not linked. when I try to link the charge 2, I get as far as the number i have to enter, and then it just stays on that screen. I pressed and held the start button on my fitbit whilst charging to reset the fitibit. My blue tooth is definitely working.
Best Answer05-10-2019 17:02
05-10-2019 17:02
Have you been able to get your Charge 2 to sync @NicksNix
It looks like you did remove the Fitbit from your Fitbit account, this step usually adds more issues. It is like closing the door then removing the door handle and complaining that the doe will not open. We still have to fix the sync issue.
Best Answer05-10-2019 18:46
05-10-2019 18:46
Best Answer05-10-2019 23:47
05-10-2019 23:47
Hi - I actually got it to pair again, but only because I downloaded the app on someone else's phone, and logged in with my account. Only then were I able to once again pair on my Samsung J6. I am quite disgusted in having to go this far just to get the fitbit to pair again. The fitibit support people did not help either, only sent on copied texts.......
