10-29-2016
10:47
10:26
10-29-2016
10:47
10:26
Thanks for stopping by @Ls1349! I'm glad you shared this, I'm pretty sure your tip will help many other users facing the same trouble with the notifications.
This new feature was implemented in the last firmware version of the Charge 2. What's new also?
If your Charge 2 displays calls, texts, events, or reminders to move:
Guided breathing exercises? Rest your eyes when using the Relax feature. The on-screen prompts for inhaling and exhaling now include quick vibrations so you can look away or close your eyes during a guided breathing exercise.
Finally a battery meter! Keep an eye on remaining battery life more easily by seeing it right on your tracker. To add this option, open the Fitbit app and tap Account > Charge 2 > Menu Items.
You have a great day too!
It's nice to see you around the Community @Melalexa93, hope you're doing great!
There's nothing to worry about my friend, you can fix this by following the steps that @wmchapman shares here.
Give it a shot and let me know how it goes! ![]()
Best AnswerHi there! I had the exact same issue but I have a prepaid phone. I called customer support and the rep had me hold down the button on the side of my fit bit to check if the notifications were on or off and I got annoyed because of course my notifications were on on my app so I assumed they were on, right? Wrong. I didn't even know that button had that option. Lol must have laid on it funny or who knows. But just in case someone didn't know like I didn't and to save yourself the phone call, here ya go. Hold down that side button for like 2 seconds and it'll vibrate and say notifications and then either off or on. Have a great day!
Yay!
I'm glad to hear you guys found this thread helpful @Terry404 @LP12!
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community, so you can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
You have an amazing week!
Best AnswerHey there! Press and hold the button on the side of ur charge 2. It will say notifications on ur screen and then either off or on. If it's off, turn it on and ur problem should be fixed. Hope that helps! 😊
Hi! On my Fitbit screen, notifications says off. How do I turn it on? On my app all notifications are switched on. Thanks!
Best AnswerHey there! Once u see it saying off, just hold down a bit longer and it
will switch to saying on. Hope that helps!
Hellooooo there @mvjfmj!
Did you try @mvjfmj's directions? As you stated, on the clock screen, press and hold the button.
Let us know if you have any other questions!
Hi, I am having the same issue as @Melalexa93 in that "When I go into the app settings to change notifications, I just get a spinning wheel and the notifications screen won't open."
I have tried rebooting everything and login in/out and cannot figure out what changed. When the Charge2 was first installed I was able to get text messages on it but later that first week I noticed the feature no longer worked.
All apps and firmware are up to date as is the IOS.
Any help is appreciated.
Thanks
There is the trouble shooting guide in for its help site at http://help.fitbit.com/articles/en_US/Help_article/1611/
Also check the phones sound setting, make sure the option to show on lock screen is enable.
Also u Der the notification settings gs you will fond the option to send a test to the tracker.
Sorry but saying you tried everything you can think of, tells us nothing and we start at the simplest.
The setup instructions or at http://help.fitbit.com/articles/en_US/Help_article/1979/
Best AnswerI actually tried one more thing and I don't think it's in any of the linked pages. I went to the Bluetooth device list on my iPhone and clicked on the "i" button next to Charge 2 and clicked on "Forget this Device".
After dropping it I paired it again and it worked.
My guess is I paired this with my iPad as well after it initially worked with the phone and doing that conflicts with the original setup.
Thanks.
Hey my friend @Timmy1127, how you doing?
Have you tried what @Rich_Laue posted here? If so, but your notifications are still not coming through, I'd try what @SunsetRunner did at the end.
I was about to suggest that until I read what you @SunsetRunner did regarding "Forget this device". Nice way to go let me say! ![]()
Keep in mind that if your iOS device is managing multiple Bluetooth connections simultaneously:
These interruptions are caused by known iOS and Bluetooth limitations.
To do the "Forget This Device" procedure, follow these steps:
Make sure all other bluetooth enabled devices are out of range when you do this.
Have a great day guys!
