11-14-2016 08:24 - last edited on 09-09-2020 10:26 by MatthewFitbit
11-14-2016 15:59
11-14-2016 15:59
@Soccer4Life_42 @Emma1112 There is actually a spinning workout shortcut that you can add to your Charge 2. You can find instructions on how to add exercise shortcuts by clicking here.
Let me know if you need any additional help!
11-14-2016 15:46
11-14-2016 15:46
Steps
1. Click the side button of your Fitbit Charge 2 three times
a. the first time the screen should turn on showing you the time, date, and how many steps you have
b. the second time the screen should show your heart rate (bpm)
c. the third time, there should be a little run icon with the word "run"
2. Tap the word run until you find a type of activity that you would like to use (maybe workout or eliptyical would be satisfactory for this action).
3. Then hold the side button until a timer starts.
4. Once you finish your activity, hold the side button again until the timer stops.
5. Read your workout summary.
11-14-2016 15:59
11-14-2016 15:59
11-14-2016 20:20
11-14-2016 20:20
11-15-2016 03:51
11-29-2016 07:41
11-29-2016 07:41
Hi, In your opinion, is it worth it for me to upgrade to the charge 2? I currently have the charge HR and it doesnt track spinning at all. I just start the workout mode and it calculates everthing based on heartrate. I was thinking the Charge 2 would do a better job of tracking spin. Thoughts? Thanks!
11-29-2016 20:16
11-29-2016 20:16
11-30-2016 16:32
11-30-2016 16:32
I would like to point out a few things to think aboit.
The Charge 2 has a spinning mode, that helps fitbit determine calorie burn
While a person is doing a spinning class, they are not stepping, they are peddling. Why would steps be counted?
Your Charge 2 is on the wrist, and therefore looking at wrist mivemwnts. How much does the wrist move when the hand is on a stationary grip?
12-01-2016 06:03
12-01-2016 06:03
Thank you!!
12-01-2016 09:46
12-01-2016 09:46
Hi! Responding to your comment about the spinning function on charge... So when you're tracking your stats for spin class do you just keep your exercise on "workout?" Am wondering what is best as mine didn't pick up any activity either
12-01-2016 09:55
12-01-2016 09:55
@Fit_Steph are you referring to the Charge or the Charge 2.
The Charge 2 has the Spin feature, the Charge does not, and your only option is to use the workout mode.
I think this can be renamed later. Don't quote me on that.
02-01-2017 10:32
02-01-2017 10:32
Hi I have the fitbit 2 and although I understand with spinning steps can't be counted , why is the distance not appearing it always says 1km when It's shown up on spinning bike as 20 km or more ? ...
02-27-2017 18:36
02-27-2017 18:36
I have a new Fitbit Charge 2 and just took a spinning class. No steps were recorded, I understand that, but my Charge 2 does NOT have a "spinning" mode as some have indicated. Just "treadmill," "elliptical," "workout," etc. Totally confused here how to get proper "credit" for a 45 or 60 minute cycling class. Thanks.
02-28-2017 05:19
02-28-2017 05:19
Hi, I believe you have to go into the app itself and add spinning manually, then it will show on the tracker
02-28-2017 08:45
02-28-2017 08:45
@JohnTVirginia There is a spinning exercise shortcut for Charge 2. If it's not already added on your Charge 2, you can follow the instructions listed here to add it.
02-28-2017 18:17
02-28-2017 18:17
Thanks, @DerrickS. It took me a little digging but I finally figured it out. Working well now.
04-04-2017 12:47
04-04-2017 12:47
Hi Derrick, I have the charge 2. I have spinning in my exercise list and it is also showing on my tracker. However when I do a spinning class it is not being auto recognised. It knows that I have done some exercise but is not picking it up as spinning. Any help would be appreciated as I have been trying to get this to work for days now.
04-04-2017 18:11
04-04-2017 18:11
Hi, it's been my experience with the Fitbit 2 that, although you may be recording exercise in "Spinning" mode, it certainly does not "count" toward your daily steps. Odd, I know. A trick that I have heard is to strap your Fitbit to your ankle to record the movement of your body during spinning (that's how it knows you are moving and if your arms don't move, it can't track the movement). I can't actually fit mine on my ankle, so I just record my estimated calories spent from spinning on MyFitnessPal, and just know that I exercised more that day than what the Fitbit records. Not great, but...
04-04-2017 23:36
04-04-2017 23:36
@Vibe Lisa there is no auto recognize of spinning. The reason you want spinning on the exercise list is so that it may be manually started and stoped.
For your auto recognized exercises, tap on the exercise tile, then tap the settings gear found in the top right.
04-06-2017 09:30
04-06-2017 09:30
It tracks your spinning class data?
