09-15-2016
20:59
10:26
09-15-2016
20:59
10:26
Very frustrating. Just got brand new charge 2 and I get to the part where they send it the 4 digit code and then it never loads. I spoke to customer service and they couldnt help as Ive done all the suggestions such as turn on off bluetooth and delete app and resart (Iphone6).
Please help? Anyone have this and fix it?
07-05-2018 20:31
07-05-2018 20:31
Charger was a typo and yes every time I tried one device I turned the Bluetooth off on the others Nad checked if anything new appeared on the paired devices list .. Also no luck
Best Answer07-08-2018 06:26
07-08-2018 06:26
Customer service was a JOKE, they said that my fitbit charge2 was synced and working with another account BUT the think is that It was bought and never used before until I broke the box's seal and tried to pair it. (I sent them a picture of the SN at the bottom of the box and that was their reply)
The pairing does not work and they are trying to push saying it being used by someone else.
Can someone else help?
07-08-2018 07:19
07-08-2018 07:19
If the unit is in your hand, it can not be used by somebody else. its unlikely but could there be a second tracker with the same ID
Even if the tracker was setup to a different account yesterday, this would not keep you from attaching it to your account today .
Since you said that yoiytried to setup with multiple devices. Where you logged into tuetsame account on each device?
Or did you create a new account, instead of choosing I have an account. on each device.
It could be that the tracker is now connected to an account you created on the 6th
07-08-2018 07:34
07-08-2018 07:34
Hi I used the same account for all, I created it on the 1st try and them used it across all.
This is the photos I have send them. Even they dont do anything to assist. Quite frustrating actually
I removed teh fitbit app from all devices and it was never synced to any device.
As the pairing NEVER worked
As soon as I enter the pair code on the phone , it desapiers from the charge 2 and the screen goes back to the setup screen
This is when I tried to connect from my macbook
Best Answer07-08-2018 08:33
07-08-2018 08:33
It is not enough to simply remove the app, you want to make sure the Charge 2 is not a trusted device in the phones /devices bluetooth settings .this includes the phone your now using .
As it says the tracker has lost comunication .
Have you tried restarting the phone and tracker .
Nothing else is connected to the phones Bluetooth .
07-08-2018 08:38
07-08-2018 08:38
Best Answer07-08-2018 09:12
07-08-2018 09:12
The point is the the pairing NEVER WORKED no any device nor shows up in any bluetooth configuration as trusted device, I never got to that point as the charge2 goes blank after I insert the pair code on the phone.
So as it did not work it did not appeared in my account and when the customer service said that the charge 2 was synced to another account that is not mine made all even worst.
Best Answer08-08-2018 01:17
08-08-2018 01:17
Here’s what worked for me:
- deleted device from Fitbit app
- opened Bluetooth from Settings
- found Charge 2, clicked on “i” and clicked on “forget this device”
- went back to Fitbit app and set up my charge 2 from the start
this one really works. tqvm
finally can pair back my charge 2 after 3 months
Best Answer08-08-2018 04:10 - edited 01-24-2019 09:05
We need to stop removing the tracker from the account with a sync issue, at best it will not help, but normally will only add problems.
IE: take the title of this thread, Charge 2 not syncing, I get the 4 digit code then nothing.
If the Charge 2 has a sync problem, a sync never requires a 4 digit code to be entered.
Needing to enter a 4 digit code tells me that it is a setup problem, not a sync problem.
08-08-2018 05:05
08-08-2018 05:05
Best Answer11-28-2018 17:44
11-28-2018 17:44
I'm having the same problem. I have tried everything mentioned here with no sucess.
Best Answer01-23-2019 19:03
01-23-2019 19:03
It's not just the Charge 2. These things have never been any good. I have had several different ones. They will work OK for a while, and then not, at random. There is no rhyme, reason, or science to the offered advice. Turn various things off, and on again, and hope for the best. From any other technology supplier, this would be laughable.
Charge 2 going in a skip, now. No more fitbit, not ever.
Best Answer01-24-2019 09:07
01-24-2019 09:07
Normally most problems may be treated to the phone or PC that is being used, making it helpful too know what device is used too setup the tracker.
04-19-2019 00:24
04-19-2019 00:24
http://help.fitbit.com/articles/en_US/Help_article/2315/ .try this will help
Best Answer04-19-2019 00:26
04-19-2019 00:27
04-19-2019 04:54
04-19-2019 04:54
07-27-2019 15:24
07-27-2019 15:24
Had a similar experience today, July 2019. The charge 2 was syncing and connected but the tracker I gave my mother was not able to receive notifications anymore, which mum wanted back as she can see if a message is important while working.
I deleted the tracker from the account, reinstalled, but it just spun after I clicked on the new code and it tried to pair, or when I clicked on notifications in the app after restarting.
What was successful for me was forgetting the device in Bluetooth settings then going to the app and clicking notifications again, and then when it says pairing required it was successful then. Such a pain though. I’ve had and still have charge HR 1,2,3 and surge and it was never so difficult before!
Best Answer09-07-2019 14:18
09-07-2019 14:18
I have to agree. Fitbit's quality is absolutely terrible. I spent $250 on a brand-new Versa. It took me 20 tries to actually get it connected, but it was constantly failing to sync. I had to reboot it several times a day. Then it died after two weeks (screen dark, didn't vibrate in charger, couldn't factory reset with the buttons).
They sent me a new Versa and so far I have been unable to complete setup. The first time I did get all the way through setup, then it said there was a tracker update available but when I tried to install the update, it couldn't connect or sync with my Versa. I tried all the troubleshooting and ended up doing a factory reset (plus deleting all the app data, uninstalling the app and reinstalling the app on my Samsung Galaxy S9).
The second time I tried to pair my Fitbit it kept saying "Found It" and I would enter the four-digit code correctly and get the green check mark, but then the app would immediately lose the connection. I'd have to click "Try Again" and it would give me another four-digit code. After the TENTH time getting a four-digit code, it finally connected.
But, of course, it failed on the next step (trying to connect to WiFi). The app just kept saying "An error occurred" and would not connect the WiFi. I ended up trying to update the software without WiFi and after about an hour of downloading, the Versa displayed a red X and went into a loop where it kept showing the "To start, download the FitBit app" message followed by the red X.
So, I had to factory reset and try again, but still the same result.
Why is software quality so poor at FitBit? Why can't you do something as simple as write software that allows a device to reliably pair on Bluetooth? I understand Bluetooth can be finicky but I'm using one of the most popular phones in the world, so you should easily be able to test these things.
I am now completely regretting buying a FitBit. What a waste of $250.
I've heard that Fitbit is in financial trouble and perhaps they've fired most of their good engineers, which would explain why software quality is so bad.
