Mine is having trouble syncing as well. I can usually get it to sync 1-2 times per day by continuing to press the 'sync now'. Before it would sync whenever I opened the app. What's up with that, I wonder??
11:17
08:29
10-17-2018
11:17
08:29
Hey guys, @GingerS, @Mbrittany and @2kyboaters, I hope you are doin' great! Oh! I'm sorry to hear about the inconveniences that you are experiencing with your Charge 2 since it is not syncing. Just to confirm, I'd like to know if you have tried all the tips in this help article: Why won't my Fitbit device sync? And if you already tried some of them, thank you. Also, I'd like to know what type of phone are you using? Is it a compatible device?
Let me know how it goes!
Best AnswerI'm having the same problem. Purchased it 8 months ago. Loaded it and registered it no problem. Worked fine on my Galaxy J3 and then on the 3rd October it stopped syncing....completely.
I've went through all the help steps..uninstalling...installing...restarting...updating....even trying on another phone...still not syncing ....2 weeks of complete frustration
12:54
08:06
10-17-2018
12:54
08:06
Hey @GrainneB, welcome to the Community! I appreciate you have taken the time to try to fix this inconvenience with you Charge 2. Well, the phone that you have, the Samsung Galaxy J3 ins't on the list of compatible devices, so I'm afraid that I can't guarantee that your Fitbit works all the time even after trying the troubleshooting recommended. In the meantime, I suggest you to try to sync it maybe with another compatible device or with a computer.
Give it a try and let me know how it goes!
11:11
08:05
10-19-2018
11:11
08:05
I hope you are doin' fine @GingerS! So, is it your Charge 2 syncing fine now? That sounds good. As you mentioned, the Samsung Galaxy S7 Edge is a compatible device, so you should not have inconveniences with it. If the issue persists, let me know.
I'll be around!
10:37
08:05
10-20-2018
10:37
08:05
Hey @Realpha, welcome to the Fitbit forums! If your Charge 2 is not syncing, I'd like you to tell me, what is the phone that you are using? Is it a compatible device? In the meantime, I'd like you to try the troubleshooting in this help article: Why won't my Fitbit device sync? And let me know if it syncs fine.
I'll be around!
