01-23-2018
19:06
18:54
01-23-2018
19:06
18:54
Charge 2
01-24-2018 01:18
01-24-2018 01:18
have a look in the Android Forum, plenty with the same issue.
comes down to version of Android and version of Fitbit app - I got an update for each yesterday and mine is working ok but ymmv
01-23-2018 19:09
01-23-2018 19:09
Charge 2 not syncing with Android app. Syncs ok with laptop. Nothing wrong with other Bluetooth devices assoicated with phone. It's been over a week. Fitbit sent a new tracker... Doesn't sync with app... Old tracker syncs with computer.... Followed all instructions by Fitbit support on the phone and it doesn't sync with the app.
Best Answer01-24-2018 00:54
01-24-2018 00:54
It would be helpful to know what phone the app is on @Ak089.
If I am reading you correctly, the old tracker syncs with the computer but not the phone. The new tracker doesn't sync with the Phoebe, does the new tracker sync with the computer?
Best Answer01-24-2018 01:00
01-24-2018 01:00
App is on a brand new phone honor 6x. It started syncing just fine when I got the phone and stopped about a week ago. Yes trackers don't sync with phone and do sync with computer.
Best Answer01-24-2018 01:14
01-24-2018 01:14
Have you removed the old tracker, replacing it with the new one, or are the two teachers now on different accounts?
Best Answer01-24-2018 01:16
01-24-2018 01:16
Removed and replaced... Either way still sync with computer and not Android app
Best Answer01-24-2018 01:18
01-24-2018 01:18
01-24-2018 01:20
01-24-2018 01:20
All of my apps are up to date I can't do anything about the version if Android I have but the phone is brand new so it's not anything old.
01-24-2018 01:22
01-24-2018 01:22
I didn't mean to accept that as a solution I still have the problem
Best Answer01-24-2018 01:27
01-24-2018 01:27
no problem.
have a look at this thread:
Best Answer01-24-2018 01:35
01-24-2018 01:35
Thanks. It seems like I'm having the same problems but I have Android 7.0 and not 8.0 ... the admin said they knew about problems with 8.0
Best Answer01-24-2018 02:08
01-24-2018 02:08
@Ak089 wrote:Thanks. It seems like I'm having the same problems but I have Android 7.0 and not 8.0 ... the admin said they knew about problems with 8.0
think there were some posters saying they had problems too and were not on 8?
08-31-2019 12:53
08-31-2019 12:53
Why fibite doesn't sync with the android
Best Answer09-01-2019 19:54
09-01-2019 19:54
There are plenty of android phones that sync with Fitbit. I'm not sure what you are saying. Does your Fitbit sync with your unknown type of phone?
