01-15-2019
11:45
17:54
01-15-2019
11:45
17:54
my wife can't sync here charge 2 after an update.
she is using the Nokia 8 sirocco
we did try to fix it but could not find the solution.
we have done the following:
delete the charge 2 from the app
remove the app
reset charge 2 but it doesn't work
remove the charge 2 from the bluetooth
when we try to reconnect it wil only say there is possible a problem with your Bluetooth
01-16-2019 16:30
01-16-2019 16:30
Hello @micr0! Thanks for sharing the inconvenience you have with your wife's Charge 2 that is not syncing after the update. I appreciate all the details provided and the steps you followed in order to find a solution, you did great. Please note that the Nokia 8 Sirocco, is not listed between the compatible devices with the Fitbit App, this might cause some issues. I will recommend to try to set it up with another compatible device or computer or to try to set it up (as you have deleted the tracker from the app) after following the instructions on the following article: Is the Fitbit app interfering with other Bluetooth devices?
Hope this helps, let me know if you have any questions! ![]()
Best Answer02-03-2019 02:39
02-03-2019 02:39
I am also having trouble with this since the update, as my charge 2 worked perfectly fine until then, and all you've done since the update is remove the Nokia 8 from compatible devices.
Is this issue actually going to be resolved or am I just going to be forced to abandon Fitbit all together because your incapable of actually being bothered to fix the issue?
10:37
08:24
02-04-2019
10:37
08:24
@VeeJohnson Welcome! It's good that the community is growing! Your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Please be aware that Android users are having issues syncing with Android 9 (Pie), you can check this thread to keep up to date with this.
Let me know how it goes!
Best Answer02-04-2019 10:55
02-04-2019 10:55
02-05-2019
10:58
08:23
02-05-2019
10:58
08:23
@VeeJohnson thank you for the update. As explained in my previous post, devices running Android 9 (Pie) are having issues syncing with Fitbit devices. This is why I shared the main thread so you can keep an eye on it. The team is working on fixing this so I can only ask for your patience while this is resolved.
I'll be around!
