@Mrspjafari @Sandee35 Welcome to the Fitbit Community! I hope you're doing well!
I will assist you with syncing your Charge 2 and sorry for the late reply. @Sandee35 thank you for troubleshooting this issue although you didn't specify what did you try. Which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here.
Let me know how it goes.
