My Charge 2 won't sync via bluetooth since october 21st. Tried everything: reset the device, unistall app and all the other tricks. The app tells me steps and heart rate, but there is no record of anything since last friday. I've added manually a few, but that's not convinient.
Welcome to the Fitbit Community @marixxx.
I would like to thank you for all your efforts looking for a solution.
Lets try these troubleshooting steps:
If you still have trouble, check the requirements in this help article Why won't my Fitbit device sync?
Hope that helps !
Bluetooth and turn Bluetooth off and back on. Turn your phone or tablet off and back on. Uninstall and reinstall the Fitbit app. If your Fitbit scale won't sync after you reinstall the app, log in to your Fitbit account on a different phone or tablet and try to sync.
Regards,
Will
Best AnswerDoes absolutely nothing to the matter. Now i removed the tracker complitely from the app and can't get it back anymore. I'm getting to the point when I need to insert the pairing code, but the the whole process crashes. My android phone (Nokia 7.2, android 11) works with other bluetooth devices just fine.
-marixxx
Thank you for getting back and share more details @marixxx.
I'm sorry to hear that you still having issues syncing your tracker.
Can I know when your device last synced ? You can find this information and firmware version in the Fitbit App and on the fitbit.com dashboard, follow the instructions in this help article: Where can I see when my Fitbit device last synced?
If your app keeps crashing or freezing it's usually because you're low on space or running too many apps at once. Other reasons for crashing apps include a spotty Wi-Fi connection or an old version of the app that hasn't been updated. Can you check please?
Also :
After this you can try the setup again, to do so, follow the steps in this help article: How do I set up my Fitbit device?
Have a nice weekend !
The last sync was october 21st. After I removed the tracker last week to reconnect it, I can't pair it again. The app is up to date (I have uninstalled and reinstalled it several times) and all the setting are the way they should. My phone finds the tracker, but won't pair it, not via bluetooth settings nor via app. The mobile tracking is working, but it consumes way too much battery and the sleep data is the thing I miss the most.
-marixxx
I'm sorry to hear that you still having issues syncing your tracker with your Android device @marixxx.
Thank you for your efforts on following our previous instructions.
Lets try this troubleshooting steps :
Reopen the Fitbit app after each step until your device setup.
If the issue persist can you try to setup with another compatible device ?
Hope that helps !
