12-30-2018
14:17
14:31
12-30-2018
14:17
14:31
I just took a hike with my new Charge 3. It vibrated thru the entire 4 miles! It was every few seconds, randomly. Very distracting and drained the battery unnecessarily. I do not have exercise cues on, that was the first thing I checked. There wasn't anything notable on the screen when I looked. It happened when I was moving and when I was stopped. Why is it doing this? It doesn't do this when I take spin or kickboxing and use it to track those workouts.
12-31-2018 09:22
12-31-2018 09:22
It's great to see you around @mer10s.
If your tracker is vibrating randomly, I recommend restarting it by doing the following:
I hope this helps, let me know the outcome.
03-07-2019 17:34
03-07-2019 17:34
I have tried this several times. The vibrating only happens when using a walk or hike exercise mode. I can't figure out why it's doing it. Or any pattern to it.
03-08-2019 11:04
03-08-2019 11:04
Thanks for the information @mer10s.
For walking, do you have the "Auto Pause" option on? If you do, I recommend turning it off by going to your exercises > Walk > swipe up and turn this option off.
About hike, are you selecting this activity or are you using running to track it?
Keep me posted.
03-08-2019 11:11
03-08-2019 11:11
I do not see an auto pause option. When I swipe up. The only thing that's there is phone GPS
I choose hike.
03-10-2019 04:10
03-10-2019 04:10
I appreciate the update @mer10s.
Since the instructions provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted.
03-16-2019 15:50
03-16-2019 15:50
I had same issue and this solved the problem. Thanks SO much!!!🙌🏼
03-17-2019 05:07
03-17-2019 05:07
Great to see new faces @CSchults.
I am glad to hear that the instructions provided here worked and that your Charge 3 is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping!
03-26-2019 09:52
03-26-2019 09:52
Hi! I tried to reset my Charge 3 but my Charge 3 still won't stop vibrating. Is there anything else I can do. It's quite annoying. Thanks!
03-27-2019 06:02
03-27-2019 06:02
It's great to see new faces @Shibafox, welcome!
Thanks for troubleshooting this vibration issue by yourself. Have you checked if the reminders to move are on? If you haven't, I recommend checking this by following the instructions provided in the help article What is a Fitbit reminder to move?.
Hope to hear from you soon.
03-27-2019 09:51
03-27-2019 09:51
I turned off Step Reminders in my iPhone App but that hasn't stopped the random vibrating from my Charge 3. What else should I do? My firmware version is 20001.49.45. This shouldn't happen to a new Charge 3.
03-28-2019 04:11
03-28-2019 04:11
Thanks for the information @Shibafox.
Keep me posted.
05-06-2019 18:05
05-06-2019 18:05
The same thing is happening to my inspire hr. Please help me.
05-13-2019 05:54
05-13-2019 05:54
My fitbit was do this and these directions fixed my problem. Thank you!
05-13-2019 09:31
05-13-2019 09:31
Ever since I got a new Charge 3, the vibrating issue is no longer a problem. Thanks! I am wary about the new Software Update. Anyone have issues with the new software update for the Charge 3? Thanks!
05-18-2019 02:22
05-18-2019 02:22
Hi, wondering if this was resolved as i also have this issue when set on walk. Very annoying!!!
05-18-2019 04:34
05-18-2019 04:34
No, none of these solutions have helped. What I have discovered is a the fitbit and my phone lose Bluetooth connectivity during the walk/hike (any activity that is not mostly stationary. Think not in a gym setting) And the fitbit is vibrating to alert me of the loss of connection. It really ruins that function of the device for me. And I am seeking out other devices to use. This will be the last fitbit I ever buy
05-18-2019 13:57
05-18-2019 13:57
Oh that is disappointing! I'd hired you would have the answer. It is soooo annoying. Thank you for taking the time to respond.
Fitbit, did you have any answers for us?
06-08-2019 09:05
06-08-2019 09:05
I am having the same problem. I have tried to reset it but it won’t stop vibrating. It is vibrating so much that I can’t get to the exercise screen and the light on it is red even though it was just charged and has almost a full battery. What should I do?
06-08-2019 14:09
06-08-2019 14:09
I turned Bluetooth off as someone on here said it was the Bluetooth disconnecting/connecting even though my phone and fitbit were both on me. The vibrating stopped but then i didn't get the map and tracking feature that i wanted so i now have to use Samsing Health app to do that. I think i should have bought a samsung watch now 😞
