10-01-2016
11:29
10:26
10-01-2016
11:29
10:26
Hey hey hey @Igobronco, welcome to the Community! I hope you are enjoying your Charge 2, besides the fact that it is not tracking your sleep in the last few days. But don't worry, I think we can fix that, just follow the instructions on this post to restart your tracker and then use it for a few nights to see how it goes!
Let me know the outcome! ![]()
Just received my Just used my Fitbit charge 2 for the first two days, everything seems to work EXCEPT the sleep tracker.... it says I went to bed at 11:00pm woke up at 12:21am and then stopped tracking until 3:59-5:34am . I got up at 6:00 am as I always do.
next night went to sleep 11:15pm tracked till 12:58 am and never tracked again.....
Have hooked up to the charger again and reset as some has said, hoping this takes care of problems, any IDEAS.... OR SUGGESTIONS??? Hate when a new product doesn't work as expected!!!!
gary
Hey @garydailey, it is great to see new faces around!
congratulations! Sounds great that you have the new Charge 2. I hope you'll enjoy all its great features. And regarding the sleep tracker, don't worry. I can give you a hand on this. Since you already tried to restart it, but it seems that it didn't work, I suggest you to try to set up your Fitbit as a new device on your iOS device. Then try it out for a few nights and let me if it works as expected.
Catch ya' later!
HELP! I have done everything that has been suggested. I have reset my tracker. I have deleted my tracker from the Fitbit app and added it back in, I have changed sleep settings from normal to sensitive. I even removed the app from my phone and added it back and redid the reset, removed and added the device back. My charge 2 still doesn't track my sleep.
Finding a manual way to track sleep defeats the purpose of having a device that comes anywhere near properly,tracking sleep.
Is there something else I should be doing to make this work? Or do I need to consider the tracker as not working properly and get it replaced! Thanks!
I have the exact same problem! Charge 2 was an Xmas gift, no sleep tracked since day one plus its tracking steps whilst I sleep, 2355 last night! I have rang customer support twice and done everything suggested, restart / remove and re add device / remove app and re add / change sleep mode to sensitive but nothing works 😒 Help!!
Hi, I'm also having the same problem regarding sleep tracking. I've restarted the device, removed and re-installed the software on the iPhone, changed sleep settings etc
I have Version 22.48.14 of the Charge 2.
I'm hoping Fitbit read these messages, and find a solution as there seems a number of people who share this problem - else this is being returned for a refund.
My sleep tracker isn't working either no data.
Best AnswerI'm having the same problem - my Charge 2 is not tracking sleep and/or heart rate correctly.
I am also frustrated that a product which is considerably expensive, and claims can do all these wonderful things, does not work properly!!
New Charge two - sleep recorded one night and like everyone else no longer records. 😢
Best AnswerThank you. It tracks sleep sporadically only tracking a few hours and 0 restless. I don't want to have to return it.
It is very sporadic for me as well, only recording 1-3 hours sleep each day when I have slept for 7-8 hours. I returned my new Charge 2 after Christmas and received a new one from Amazon this week, but the problem is the same. Fitbit needs to fix the software problem!
I agree it seems like a software issue
Best AnswerI
I logged in onto my home computer and that seems to take care of the problem.. now works on app and home computer
Going to have to try that.
