09-27-2016
06:49
10:26
09-27-2016
06:49
10:26
Hi,
Anyone have experiance with thier HR 2 on menu missing after you have press the buttom.
Just upgrade my Fitbit from HR to HR 2 in less than a week. got excited with the new HR2 and retired my HR.
Wanted to get use to operating the HR 2, use it and syn with my Iphone with no isse. happy with the batt life as well. One thing I was curious, the sudden disappearing of 3 menu when i was surfing the menu buttom.
Able to surf or navigate the first 3 menu which started with the watch face, follow by the BPM, follow by the exercises. then it goes back to the 1st page of watch face again. The Relax, Stopwatch and Alarm menu just disappear. Tried the reset method, didnt get backthe original setting of the factory.
can anyone advise or help me to get the menu back.....
Thanks
09-27-2016
09:49
05:13
09-27-2016
09:49
05:13
@PeterLok I can definitely help you out! You should be able to re-add these menu items by:
Keep me posted if this helps!
10-03-2016 06:48
10-03-2016 06:48
@Vk1118 Thanks, that worked for me. Had to reinstall the Win 10 app (don't normally use - on computer always used to website dashboard) but all options were there (unchecked), checked them all and they returned with the next sync.
09-27-2016
09:49
05:13
09-27-2016
09:49
05:13
09-28-2016 07:47
09-28-2016 07:47
09-28-2016 09:37
09-28-2016 09:37
My menu just disappeared today. I can not find the "menu items" button. I see account button on app, but that is as far as I get.
Best Answer10-02-2016 19:36
10-02-2016 19:36
Same thing happened to me - Only the Exercise (tap menu) remains on the button menu. Also, I do not see the 'menu items' button on the App account page. On the the Dashboard, the menu items list is there but only Exercise is listed, all others have disappeared.
Please help, I'd like to be able to use the other features.
Best Answer10-03-2016 06:04
10-03-2016 06:04
I fixed mine. I think I used the app on the computer - not my phone. I clicked on the little gear on the right side of the dashboard page after I logged in for settings. Then clicked on devices and then Charge2. If you scroll down you'll see menu items. You can show or delete items and change their order by dragging them up or down.
10-03-2016 06:48
10-03-2016 06:48
10-03-2016 21:05
10-03-2016 21:05
Hi BruceBu,
Have followed @DerrickS instruction as per below and it works for me.
Opening the Fitbit App.
2. Click the Account button.
3. Click the Charge 2 tile near the top.
4. Click the "Menu Items" button.
5. Select which menu items you want and which order.
6. Sync your tracker for the changes to take effect.
Hope this helps.
Best Answer10-04-2016 05:39
10-04-2016 05:39
@PeterLok - thanks, that did work as long as it was the Windows 10 App, not iOS, don't know about android. Anyway, after restoring with the Win10 App and syncing, everything showed up again on iOS phone, internet dashboard, and the device.
11-18-2016 19:48
11-18-2016 19:48
Best Answer11-21-2016 06:41
11-21-2016 06:41
@drrhodes Welcome to our Community!
Where did you removed the menu items, from the app or the tracker? Could you share a picture or screenshot (if it was from the app). If you removed the item from the tracker you should be able to restore it by following the steps described in this thread by @DerrickS and other users. If you remove the item from the app I would like to know which OS are you using (Windows, Android or iOS). In general if you are using Android with the new menu or iOS just go to the bottom and tap the (show hidden or Edit) button to see all the tiles that you can add or remove from the app.
Let me know how it goes!
11-21-2016 08:14 - edited 11-21-2016 08:15
@drrhodes are you referring to menu items
Or customizing the stats
Either way it should be a check or uncheck of the box. Then a sync, that gets automatically scheduled
Best Answer11-21-2016 11:46
11-21-2016 11:46
Best Answer01-13-2017 07:34
01-13-2017 07:34
Somehow, I have lost my menu items as well. I followed the steps provided here and updated my ios app, but the only menu item I have is the heartrate. Is there any thing else I can do?
Best Answer01-14-2017 15:18 - edited 07-03-2017 17:10
IF your unable to replace the menus with the instructions above, then do an add device, wth the replace option. Add your Charge2 as a replacement for itself
Best Answer07-02-2017 17:09
07-02-2017 17:09
I've had the same problem. I have the relax option checked on all my devices but it still doesn't show. Are there other solutions to try?
Best Answer07-18-2017 08:09
07-18-2017 08:09
That doesn't help.
Best Answer07-19-2017 12:54
07-19-2017 12:54
@AmyRuth, what is it that doesn't help and why do you say it doesnt help? Remember that we need you to be our detective.
Have you tried rearranging tye menus?
Best Answer07-19-2017 14:23
07-19-2017 14:23
Best Answer03-04-2020 10:14
03-04-2020 10:14
Well, It's 2020 now. This is happening to me also. Just verified it is all ticked on the Menu, resunched it three times and I still do not have the Relax or Exercise function any longer. Just Notifications and Battery and I am not even sure Notifications is actually working.
