Charge 2 not updating data
I wear my charge 2 constantly and it's not recording and updating data onto my phone. My phone says the battery for my charge 2 is low aswell, but its fully charged. The app is all up to date so not sure why they aren't working together?
1 REPLY 1
@Lizziecrocker89 Welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your Charge 2 not updating your data. This sounds as if your tracker isn't syncing. Which phone are you using? Is it compatibleYou can try the following:
  • Go to your phone's bluetooth settings and remove all devices listed there.
  • Restart your phone and restart your device
  • Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  • You can find additional suggestions here.
Let me know how it goes.
Alvaro | Community Moderator
