04-19-2020
03:03
09:49
04-19-2020
03:03
09:49
Last night around 3am my Fitbit started vibrating continuously then switched off. I have tried to reset and charge but will not switch on any ideas? Thanks
04-27-2020
11:55
08:12
04-27-2020
11:55
08:12
@Lisamarieauchie Thanks for joining us! Sorry for the delay in my reply.
Let me help you with your Charge 2 not working and thank you for troubleshooting this issue. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves.
Let me know how it goes.
