Charge 2 screen cracked
The screen is cracked on my charge 2, is this a common occurance and what are my options for a replacement screen?
22 REPLIES 22
@Lizwilliams1982 Thanks for joining us!
Let me help you with the cracked screen on your Charge 2. I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
Alvaro | Community Moderator
My screen is also cracked. Are there replacements?
My Charge 2 has also acquired a cracked screen. All else is functional, would rather repair it than retire it if possible. Been a fitbit user for years, never had damage like this to any of the prior models. Is this a lower quality material than prior screens?
@Mrsamplias @Ali__ Thanks for being part of our Community!
Let me help you with your damaged Charge 2 screens. There aren't repair centers so it would be better if you let our Support team know about this for further assistance. @Ali__ I have created a ticket for you so our Support team will reply via email. @Mrsamplias I noticed that you already have a ticket so keep working with the team to find a solution.
Keep me posted.
I also have a cracked screen and would like to know my options. Thanks!
I wonder if there are any options--Fitbit would probably prefer that you scrap it and upgrade to a new one!  (I too have had a cracked screen for awhile, but as long as the device is still working, I will use it--However, I have assumed that jumping into water with it is no longer possible/good idea!)
My Fitbit charge 2 screen has also cracked unexpectedly.. this has happened to me before and I was sent a replacement... would I still be able to claim for a new replacement? Clearly this is a common fault with the Fitbit charge 2 😞
My Charge 2 screen is also cracked - as is my daughter's - in exactly the same way - a vertical line from top of watch to bottom.
I also have this problem. Can you create  a ticket for me as well?
My screen has also cracked vertically straight down the face of the screen. Please can you let me know what options are available
Thanks
Mine is cracked like the others, but still working. Are there any options for repair?
My Charge 2 screen is cracked. Although it is still functional. Please help with either how to repair or replace it.
Thank you.
Hi,
My screen cracked again.  This was my replacement for a previous cracked screen.  I have reached out twice to request chat support but haven't heard back from anyone.  Can you please open a ticket for me as well?
My screen also cracked due true heat they only give a discount but that's so low it's cheaper te buy a new one  somewhere else. But I think its bad and I am doubting if I should buy a new one! Is this only a charde 2 problem?
Interesting that you mentioned heat.  I am on my second one and both have cracked in the summer - 2 summers in a row!.  I don't know how much the discount is, but I would not opt to buy another Charge 2 myself.
  • Thank you for your assistance.
My screen is also cracked. I had a similar issue earlier this year and was able to report it via the website and was given a replacement Charge 2. However just 3 months later the replacement has also developed a crack on the screen. It's not affecting the functioning of the Fitbit but I feel that the quality of the items isn't very good and I can no longer see an obvious way of contacting Fitbit support to report it.
Thanks
My screen is cracked as well.  Any fix for this?
