05-02-2023
02:41
04:28
05-02-2023
02:41
04:28
Happened again that activity not registered 🙄
05-03-2023 04:29
05-03-2023 04:29
Hi, @JeniLlanfach , some activities are more difficult to auto detect than others. If you find auto detection is not working well for you I would recommend starting and stopping your activity via the exercise app on your Charge watch. That way you will always have your activity recorded and you will also get an extra stat - your distance (which is not available for auto detected activities) and if desired you can also get a map if you connect your Fitbit to the GPS on your phone.
Welcome to the forums!
05-03-2023 04:31 - edited 05-26-2023 12:54
Hi there, @JeniLlanfach. Welcome to the Fitbit Community Forums. I understand how you must be feeling.
To better assist you, please let me know which activity is your Charge 2 not tracking?
In the meantime, I recommend restarting your Charge 2 as suggested here How do I restart my Fitbit device?
Best Answer05-04-2023 01:07
05-04-2023 01:07
You can try restarting your tracker by doing the following: Plug the charging cable to your computer or UL certified wall adapter. Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Regards,
Wll
