04-20-2023
03:42
08:04
04-20-2023
03:42
08:04
screen is not visible even in dark have tried all fixes but no change
this is the second unit i’ve had with the same problem
Hi there, @johnb30. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 3 before reaching out.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
Plug the device into the charging cable.
While the device is plugged into the charging cable, hold the button down for 15 seconds.
Remove your finger from button.
Remove the device from the charging cable.
Plug the device into the charging cable again.
The smiley face icon appears on the screen.
Regards,
Will
