09-05-2020
08:10
09:08
09-05-2020
08:10
09:08
Charge2 quit with no notification. Unresponsive to charge.
09-06-2020
12:17
05:09
09-06-2020
12:17
05:09
@Lanaf Welcome to the Fitbit Community!
Let me help you with your unresponsive Charge 2. This could either be a charging issue or a display one so I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your device charge.
Let me know how it goes.
09-09-2020 05:55
09-09-2020 05:55
Best Answer09-09-2020 09:10
09-09-2020 09:10
Mine has done the same thing. I’ve tried cleaning, restarting, etc. nothing. What do I do next? Where can I take it for repair?
Best Answer09-18-2020 17:54
09-18-2020 17:54
Thanks for the suggestions but there is no change, the Fitbit will not turn on.
Best Answer09-18-2020 18:00
09-18-2020 18:00
Thanks for the suggestions but my Fitbit still does not turn on.
Best Answer09-19-2020 11:27
09-19-2020 11:27
mine just died too. Tried the hold down button while plugging in for various durations/repeats and no luck. No trauma to watch, just stopped
