04-25-2018
11:58
18:54
04-25-2018
11:58
18:54
I Got My Fitbit For Xmas This is the second strap i have it breaks on one side has any body had this problem ?
04-25-2018
12:00
06:33
AlvaroFitbit
04-25-2018
12:00
06:33
AlvaroFitbit
Yes, I eventually had to get a new strap through Fitbit. They were very quick and efficient about it. I believe Amazon also sells them.
04-26-2018 07:24
04-26-2018 07:24
@Mikeysmith @Rhoadsontheroad A warm welcome to our Community! Sorry to hear about your damaged wristband. In this case please follow @Rhoadsontheroad suggestion and let Support know about the issue so they can help you. I noticed that you already have a ticket with them so I wanted to know what did they tell you? Were they able to help you?
@Rhoadsontheroad happy to hear that Support was able to help you!
Let me know how it goes!
Best Answer06-25-2018 13:48
06-25-2018 13:48
Hi how much does it cost to replace the strap on my Fitbit Charge 2 - it was a present for last Christmas and one of the straps is broken - not that i would have expected to break in such a short time though.
thanks
AnnaGA
06-25-2018 14:11
06-25-2018 14:11
I've had to replace mine twice. And, I see that the same end is failing again on my third band. I wear mine on my left wrist, and the part of,the band that is above the tracker is loose. I've been very careful to treat it carefully, not putting undue pressure on the band. This is frustrating!!!
06-25-2018 16:08
06-25-2018 16:08
The strap on mine has just broken. I paid $40AU for it a few months ago to replace the one that broke on the original. Getting rather disappointed with Fitbit overall as this Charge 2 is a replacement for my first fitbit. The first one developed a faulty charge cable and had to be replaced at my cost. It then developed a faulty charge port and I had to pay the difference between the original, and the Charge2, as the original was no longer in stock. As a pensioner that has been using the fitbit to great effect in weight loss and increasing my fitness levels I am not in a financial position to keep paying for replacement bands.
01-16-2019 13:22
01-16-2019 13:22
Hi. I also have had a problem with the strap breaking. I had my Fitbit for my Birthday last March and the first strap lasted less than 6 months. I have noticed this evening that my second strap has started breaking. Have you had a second replacement?
Best Answer01-16-2019 15:53
01-16-2019 15:53
This is also my second strap to break, And it now seems that they don't sell the straps anymore because the charge 3 is now out unlessyou pay 59.99 or get a cheap **ahem** rip off from eBay or Amazon!
Best Answer01-16-2019 17:13
01-16-2019 17:13
Best Answer01-17-2019 00:02
01-17-2019 00:02
Best Answer01-17-2019 03:09
01-17-2019 03:09
Help, pleeeease. My charge 2 strap is broken & absolutely nowhere on the website can I find how to actually BUY a new one. I can find fit one, change one etc etc but not actually to acquire one
Best Answer01-17-2019 11:02
01-17-2019 11:02
Thank you all for your comments. I have contacted https://contact.fitbit.com and they are assessing the case. They have opened a case and I have sent off a photograph. I will let you all know what they say. At present they say this is 'unexpected and unintentional', so we will see if they have anything to add and what they suggest I do about it.
MargaretSwindon
Best Answer01-17-2019 11:09
01-17-2019 11:09
