08-09-2018
19:23
18:22
08-09-2018
19:23
18:22
I've had my fitbit for a little over a year now with no problems but today it suddenly went to the setup screen without reason. It doesn't sync or connect to my phone so I can't try firmware but I've tried restarting it multiple times, unpairing and re-pairing with my phone, logging out of the app, and while keeping it plugged in. What should I do?
08-10-2018 06:34 - edited 05-06-2025 07:16
Welcome to the Fitbit Community @dueckmeister! Thanks for already troubleshooting this inconvenience with your Charge 2, nice way to go!
In order to fix what you're getting on your screen, please try doing the following:
Let me know if this solves your issue, I'll be around if you need me!
08-11-2018 23:31
08-11-2018 23:31
I've tried all of those things except the firmware- since the fitbit can't connect, it can't update.
11-24-2018 12:35
11-24-2018 12:35
I'm having the same problem.
I tried everything you said
Nothing has changed
11-25-2018
07:27
07:16
11-25-2018
07:27
07:16
@Alex2552 It's great to see that you've visited the Fitbit Community! Sorry to hear that you can't setup your tracker. Which phone are you using? Is it compatible? Do you get any sort of error message? Try using a different phone to setup your tracker also make sure no other bluetooth devices are nearby to avoid interference from them.
I look forward to your reply!
Best Answer11-25-2018 11:19
11-25-2018 11:19
Hi
I use à Samsung Galaxy A5
Everything was fine until yesterday morning (it’s been 2 years since I bought my Fitbit)
I charged it during the night because the battery was low
when I Woke up the in the morning the Fitbit was stuck on the setup image.
it can’t sync anymore .
I also tried with my IPad, my PC and my boyfriend’s cellphone..
thanks for the answer
Alex
05:46
07:16
12-16-2018
05:46
07:16
@Alex2552 thank you for the update and sorry for the delay in my response. I suggest you clean the bluetooth connection on your phones by going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. Also when setting it up make sure all other phones and bluetooth devices are away so they don't interfere with the process.
Keep me posted!
Best Answer10-24-2019 11:53
10-24-2019 11:53
My Alta HR did the same thing. I did all the suggested fixes on here and nothing worked so I called the Helpline. She suggested I tap on my picture in my account on my phone app and then tap on Set up a Device. Even though there was a similar "Setup" button on previous screens on my phone when I tried to pair the two, going in through my account instead worked like a charm!
10-28-2019
10:08
07:15
10-28-2019
10:08
07:15
@Bip1949 It's great to see that you've visited the Fitbit Community! Sorry for the delay in my reply.
I am really happy to hear that our Support team was able to help you and thank you so much for sharing what you did to correct this as I am sure it will help other members in the same situation.
I'll be around.
Best Answer12-27-2019 11:23
12-27-2019 11:23
If you’re Fitbit is stuck , Make sure you’re doing Updates! I thought I needed to reset my syncs (which was not working!). I logged in App Store and realized I hadn’t Updated !!
So simple! Do this first!
02-11-2020 10:39
02-11-2020 10:39
I have done all you recommended several times, I've had this for 4 days I'll just return, I shouldn't have all this hassle with a brand new product, furthermore all the thousands of comments with fitbit trouble is not worth it.
Best Answer12-13-2020 03:20
12-13-2020 03:20
I have exactly the same problem. I have tried to follow the instructions in this thread, but the watch is stuck on the setup screen, and the App can't synch with it.
12-13-2020 06:32
12-13-2020 06:32
11:00
07:15
12-15-2020
11:00
07:15
@DJC92 Thanks for stopping by!
Let me help you with this and thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
@Bip1949 thank you for trying to help.
Let me know how it goes.
Best Answer10-19-2021 09:34
10-19-2021 09:34
I tried this too, on my Charge 2. It worked!!! Thanks so much!
Best Answer06-07-2023 08:16
06-07-2023 08:16
Hi. I tried all the tips you posted but my fitbit still shows the setup message. What to do?
06-07-2023 08:37
06-07-2023 08:37
