08-18-2019
21:16
21:38
EstuardoFitbit
08-18-2019
21:16
21:38
EstuardoFitbit
Prompted the other day to update... It seems to have stalled. Now I have a white line display. I sync with app fine it counts steps and all but no display other than white line. And doesn't vibrate when calls come in. I've tried to Uninstaller but to reinstall I get to the four digit code to enter but nothing but white line displayed, so can't get the code to reinstall
08-19-2019
09:47
11:23
AlvaroFitbit
08-19-2019
09:47
11:23
AlvaroFitbit
Hello @Kchappyday may I ask what phone you have?
Also by uninstaller did you remove the Charge 2 from your Fitbit account? Doing this will only add problem's.
08-19-2019
11:27
11:44
08-19-2019
11:27
11:44
@Kchappyday Welcome! It's good that the community is growing!
Let me help you with your Charge 2 not updating its firmware. @Rich_Laue does mention something important. If you removed the device from your account then it may be more difficult to complete the update. Still try refreshing the link between your phone and your tracker by doing the following:
Let me know how it goes.
Best Answer08-21-2019 02:16
08-21-2019 02:16
08-21-2019 04:17
08-21-2019 04:17
I have the same problem - phone says to update software, but no mention of update on PC Dashboard. Phone & watch have syncing issues a times. After about 1 min of updating I get an exclamation mark on Fitbit line & phone says to try again. I have turned everything on & off several times, logged out of app on phone, restarted my watch several times but no joy. Online says it try from PC but cant find where I should do this from dashboard
Best Answer08-21-2019 05:20
08-21-2019 05:20
Have the same issue with my Samsung A8.
I deleted my fitbit and now have www.fitbit.com/setup. When I go there there is no where to add a device. Bluetooth says cannot pair with device.
Ready to throw in the trash and buy something that actually works.
08-21-2019 05:43
08-21-2019 05:43
08-21-2019 05:57
08-21-2019 05:57
08-21-2019 06:00
08-21-2019 06:00
Best Answer08-21-2019 08:16
08-21-2019 08:16
Up in the top corner of every page is a link to Contact Support.
If your asking for help with a phone/Charge2 update issue it would be helpful to include the phone model. Most of update issues are related to sync issues or the app going to sleep when the phone screen turns off. On android start the update and move the Fitbit app to he background.
04-30-2020 07:05
04-30-2020 07:05
Turning the screen timeout timing to 30 minutes vs. 30 seconds worked here. It seems as soon as the screen darkened to go to sleep, the sync stopped.
Try this!
Then, of course, turn your screen timeout back to whatever you like.
Cheers!
Best Answer04-30-2020 11:33
04-30-2020 11:33
I start the update and move the Fitbit app to the background.
Now when the display times out, their is no issue.
