10-29-2019
20:19
11:53
10-29-2019
20:19
11:53
My charge two will not reset. Date and time display still Sunday 27th tried to reset tracker tried to change clock didplay with app. Still no results it is tracking steps though with app
@SunsetRunner Welcome! It's great to see you around!
Let me help you with your Charge 2 date. Is your tracker syncing? It seems that it isn't so the date won't update. Which phone are you using? Is it compatible? You can try the following:
Let me know how it goes.
@SunsetRunner thank you for the update and sorry for the delay in mine.
You could try changing the timezone and clock face on your Charge 2 (select a different timezone save and sync then select the correct one again save and sync. For the clock face just select a different one. You could also try setting up your device again on your account. Tap the top left button, then your tracker's icon and finally the trashcan icon to remove it from your account. After this follow these instructions to set it up again.
Keep me posted.
