12-14-2020
06:58
03:18
JuanJoFitbit
12-14-2020
06:58
03:18
JuanJoFitbit
I recently noticed my fitbit had the wrong time on it. I checked with the app and realized it wasn't pairing anymore. So I removed the device and tried to add it back. It'll see the device and and give me a code but doesn't do the final pairing. I completely drained the Fitbit, recharged it and tried again and it still stalls at that last step.
12-15-2020
03:14
07:52
12-15-2020
03:14
07:52
@Piece0fpi Thanks for stopping by!
Let me help you with this and thank you for troubleshooting this issue. I suggest you clear the link between your phone and your tracker by doing the following:
Let me know how it goes.
03:14
07:52
12-15-2020
03:14
07:52
Hi @Piece0fpi, welcome to our Fitbit Community. I appreciate the time spent trying to get the syncing issue resolved before contacting our forums. I'd like you to follow the troubleshooting steps that are listed in this help article. This article contains steps that you already tried but you can skip them and proceed with the rest.
Finally, monitor your tracker during the next 24 hours and see if it syncs properly and shows the correct time.
Keep me posted on the outcome.
Best Answer12-15-2020 06:00
12-15-2020 06:00
I'm having similar problem with my charge 2 syncing with my pixel 3. I've tried all the troubleshooting tips recommended. I get a code to set up new connection but it fails. I was showing steps, but that tile went away as did my health metrics tile and my sleep tile and there is not an option to add those tiles back. After trying all the different troubleshooting steps it isn't even showing steps or syncing steps. It was acting a bit weird about syncing for the past couple of weeks and this past weekend I traveled between timezone (eastern and central). But now it is totally not syncing at all, I did once get a message about passcode not correct, but usually it just doesn't sync. thanks
07:39
07:51
12-15-2020
07:39
07:51
@NancyMuse Welcome to the Community.
Let me help you with this and thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
12-29-2020 18:29
12-29-2020 18:29
Did you find a resolution? Same thing is happening with my Charge 2 and Pixel 2. Thanks.
Best Answer12-30-2020 06:48
12-30-2020 06:48
