Charge 3 - Blank screen
ANSWERED
My daughter has a Charge 3 and the screen is constantly blank.
App showing device is 100% charged and there are no firmware or software updates required.
I’ve tried the fix of holding the button for 15 secs while connected, then disconnecting and reconnecting power but no success. Is there anything else that can resolve this issue?
1 BEST ANSWER
Accepted Solutions
Thanks for getting back to us @Tryfan. I'm sorry to hear that your daughter's Charge 3 is constantly blank. Thanks for mentioning the steps you followed in order to turn on the device. I'll be happy to assist.
Please confirm that you followed the steps of help article: How do I restart my Fitbit device?
Also, since you mentioned the 15 seconds, did you try also the long restart:
  1. Connect the device to the charging cable.
  2. While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
  3. The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
  4. The device turns off.
  5. The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
  6. Remove the device from the charging cable. The device shuts down.
  7. Important: Plug the device into the charging cable again.
Have you also tried changig the device's clock face: How do I change the clock face on my Fitbit device?
7 REPLIES 7
Andrea,
Thanks. Have tried the steps in the link and the steps you put in the thread but still no response from the watch. Steps are still being counted and syncing with the app.
Getting frustrating as feeling the vibrations when pressing the button.
Moderator edit - personal information removed.
Thanks for getting back to us and for confirming that you've tried the recommended steps @Tryfan. I'll be glad to continue assisting you.
Our Team will be more than happy to have a closer look at this.
Please fill up this form with all the needed information. Our Team will reach back to you afterwards.
Please keep in mind, that this form is for you alone. If other users try to fill it up, they might not get an answer from Support.
I've had the same issue for the last 2 years. So far there's been no fix other than buying another Fitbit that I can't afford right now. Google also wants me to transfer from my email to a Google account but I can't do that because I can't get the code off a black screen. Not sure if anyone has a fix for the charge 3 anymore.
Forgot to say I've tried everything you did and nothing worked for me either. Maybe someone can help with the issues.
Welcome to the Fitbit Community, @Kath2023 I'm sorry to hear that your Charge 3 also has a blank screen. Thank you for letting us know that you've tried everything. I'll be happy to assist.
I understand how frustrating this could be and the recommended steps in order to fix the display issues on the Charge 3 are on my post that is marked as Best Answer.
You can migrate your account to Google without having a tracker. Follow the instructions of help article: How to move a Fitbit Account to a Google Account
I've tried everything you mentioned and I get nowhere. I need to transfer my Fitbit to a different phone because my other phone died. I have the app on both phones yet I can't transfer to the other phone without a code. Since my Fitbit screen is black, I can't get the code. Now what do I do?
Hi @Kath2023, thanks for getting back to us and for confirming that you've followed the recommended troubleshooting steps. I'll be happy to continue assisting you.
Thank you for your messages and efforts. Our Team will be more than happy to have a closer look at this.
