01-20-2023
04:28
17:45
LucioFitbit
01-20-2023
04:28
17:45
LucioFitbit
I have set a smart alarm and a regular alarm, both for the same time. I can go in and set one of them to disabled ("off") but the other one will not disable. I end up having to delete it. Issue recurs even smarter restarting the device. This is clearly a bug, please release a FW update to fix it.
01-24-2023
17:49
08:30
01-24-2023
17:49
08:30
Hi there @JoeSchmoe2, it's good to see you around in the Community.
I appreciate the troubleshooting steps performed and the comments. I'd recommend you:
- Erase all alarms
- Restart your device
- Set up the alarm(s) of your choice
Also check this article, How do I manage alarms on my Fitbit device?.
