11-02-2018 06:50 - last edited on 11-17-2020 15:03 by MatthewFitbit
My Charge 3 is not even a month old and the bands are falling off. It seems the clips on the Charge 3 are failing already.
This is happening with original and accessory bands.
I've been chatting with Fitbit via Twitter Direct Messaging about this. Gonna have to get on the phone and request a warranty replacement it seems. In case you need it here is Fitbits phone number 877-623-4997
07-06-2019 03:17
07-06-2019 03:17
Same problem. Watch band falls off because the clip/notch is wearing down. A little disappointed because I have over 30 watches and have never had this problem before. Probably need a redesign of the clip on the watch.
08-01-2019 01:10
08-01-2019 01:10
I received my charge 3 just 10 days ago and immediately swapped out the white band for the black. Both strap parts locked in and no issues. Worn 24-7, swimming, working out and in shower. Yesterday decided to wear the white band. 1 part locks (part with buckle) but the other will not, no matter what I try. I've looked at the instructions for replacing a band (it's not rocket science). But based on this forum, I'm gathering that this is a recurring issue. Contacted Fitbit support, who suggested that I look at the instructions again or reach out to Amazon (from whom I purchased the charge 3). This must be a design or manufacturing flaw, given so many people having the same problem.Very disappointed and am considering returning everything (add'l strap, extra chargers and screen protectors) and getting something else.
08-01-2019 01:18
08-01-2019 01:18
I had the same problem with my new Fitbit from Amazon.
I find that if you give the bands a good thug out, after you click them in, it locks the internal locking mechanism.
It worked for me and bands haven't fallen off since.
I hope this works for you.
08-01-2019 13:10
08-01-2019 13:10
I have had mine for 2 weeks and band has come away 4 times. I have no confidence in it and am sure I will look at my wrist one day and it will be gone. My alta hr connections were much better. Will probably sell on.
08-01-2019 13:42
08-01-2019 13:42
08-06-2019 07:33
08-06-2019 07:33
I was having the same problem - what I did was put a drop of WD40 on the latch mechanism and exercise the release button. After repeating a couple of times, the latch works correctly and holds the band in place. Hope this helps.
08-10-2019 23:16
08-10-2019 23:16
I've been through 3 of these devices and they're all garbage. This one had the band fall off, at first I thought it was the bands quality but the mechanism on the watch itself doesn't work. The spring sticks. These things are garbage and I'll never get another Fitbit. Anyone know of a fix?
08-11-2019 09:58
08-11-2019 09:58
Springs usually stick because of dirt getting into the mechanism.
08-11-2019 12:36
08-11-2019 12:36
08-11-2019 20:02
08-11-2019 20:02
08-11-2019 20:17
08-11-2019 20:17
09-09-2019 20:00
09-09-2019 20:00
What was your method of ensuring it is latched correctly?
09-10-2019 06:12
09-10-2019 06:12
I exercised the release buttons kept shooting it with WD-40 until the release button became flush (smooth) with the rest of the band. Been working great since, but I haven't released the band either.
09-25-2019 00:40
09-25-2019 00:40
Thank you. That worked. I always wear mine and even so debris does accumulate in the crevice. Gave it a good cleaning and applied WD40 as you suggested. Will see how it does.
09-25-2019 05:56
09-25-2019 05:56
09-25-2019 08:57
09-25-2019 08:57
Looked like dried shower gel lol. Still yuck!
09-25-2019 23:56
09-25-2019 23:56
I have the same problem. With a magnifying glass I can see the clips on the pebble are broke. Fitbit support seems to have no idea what I am talking about. It looks like the pebble is attached with 2 screws. Should be a part that can be replaced.
09-26-2019 07:18
09-26-2019 07:18
10-13-2019 19:44
10-13-2019 19:44
The band started falling off after about 10 months. I thought it was a defective band and threw it away. I put the original band on and it falls off several times a day. I keep it clean and have tried the wd40 mentioned in this thread but it does not work. The button on the top will not move back up into place. This is my third Fitbit and the worst. Searching for an alternative but shouldn’t be after only a year.
12-02-2019 11:17
12-02-2019 11:17
I lost mine at mall because of this. Luckily someone turned it in. How do I get it fixed
