11-11-2018
07:19
15:03
11-11-2018
07:19
15:03
With Charge 2 after a run without my phone I could see the map with pace and time. Charge 3 does not do that. And all my GPS system on phone and device are on
11-12-2018 05:20
11-12-2018 05:20
Welcome to the Community Forums @Gr255! The connected GPS feature on Fitbit Charge 2, Fitbit Charge 3, and Fitbit Versa works with the GPS sensors in your nearby phone. To get GPS data, including pace and route for your workout, you must select a GPS exercise from the Exercise app on your device and bring a GPS-enabled phone with you. We recommend turning off Wi-Fi on your phone when using connected GPS to improve the experience.
When you choose a GPS exercise, your device vibrates when your phone finds a GPS signal. If your phone doesn't find a signal immediately, keep in mind that environmental factors including tall buildings, dense forest, steep hills, and even thick cloud cover can interfere with your phone’s ability to connect to GPS satellites.
For best results, wait for your phone to find the signal before you start your workout. However, if you don't want to wait you can start your workout and GPS tracking begins when your phone finds a signal.
Note that your device uses your step count to calculate distance until it finds a GPS signal. In this scenario, your total distance calculated for the workout may be slightly less accurate than if GPS data were available for the entire duration. For more information, see How accurate is GPS?
Requirements:
Troubleshooting:
After verifying all the requirements, try using GPS again by following the instructions in How do I track my workouts with my Fitbit device?
If you're still having difficulty, try these troubleshooting steps:
Give this a go and let me know the outcome!
Best Answer11-16-2018 08:03
11-16-2018 08:03
I'm having the same problem. I have only had my Fitbit for about a week, and when I first got it, I was poking around on it and found a GPS map and the ability to log and exercise as a hike. Now, I can't seem to find either. I do a bit of trail running, but I would prefer to log the activity as a hike, rather than a run.
01-15-2019 10:13
01-15-2019 10:13
Can anyone confirm if a logged activity should show a MAP when logged by a Charge 3, in the same way as the Charge 2 does?
If i track a walk using my charge 2, when i am finished i can see a map of my walk when i look at the dashboard.
But if i do exactly the same using my Charge 3, I get no map.
So how can i get it to show the map for Charge 3 logged activities?
Please help.
01-15-2019 10:42 - edited 01-15-2019 10:45
Hi @Reedee, welcome to the forum. Yes, Charge 3 shows the map after the workout IF GPS functionality was enabled. If you swipe to the left on your clock face, then tap on Exercise app on your tracker and swipe to the left again to find walk exercise (I assume you have as one of the 6 shortcuts?). While on Walk, swipe up - you'll see Use Phone GPS option (should be on). Please, let us know if you have it set up like that. Have a great day!
One more thing... do you manually track Walk or allow Fitbit do it automatically? If you don't start tracking walk manually - GPS will not be used.
Best Answer01-15-2019 11:22
01-15-2019 11:22
Best Answer01-15-2019 11:37
01-15-2019 11:37
Just want to confirm that you're not carrying both trackers (connected to the phone via BT) when walking, correct? Charge 3 doesn't like to be connected to the BT along with other devices - just want to confirm that this is not the case.
I don't have Charge 2 and don't know whether there's a difference as it comes to specific setting requirement... May I ask you to check if you have Location enabled with High Accuracy and Power Saving Mode on the phone turned off?
Best Answer01-15-2019 12:18
01-15-2019 12:18
Best Answer01-15-2019 12:59
01-15-2019 12:59
@Reedee, thank you for providing additional details!
Yes, please turn off power saving and keep location setting on high accuracy. If you have wi-fi enabled - turn it off. Please, let us know if you're still unable to see a map after a workout!
01-16-2019 09:59
01-16-2019 09:59
@Reedee, ran across one post today and figured I'd share... If all else fails, you may try to remove Charge 2 from Fitbit app and unpair it from the phone, then see if Charge 3 starts working as expected. Have a great day!
Best Answer01-16-2019 10:56
01-16-2019 10:56
Best Answer01-22-2019 06:02
01-22-2019 06:02
Hi sorry to but in on this chat but I am new to all of this and don't know where to start. I got my fitbit charge 3 last week as im planning to compete in a 30 hour walk, I have a Samsung Galaxy 9+ they are paired together but I cant get to track my walk with a map which I would love so it also shows you where iv been, RiseAndShine I see you mention tap on the exercise app on my tracker then swipe left to find walk which I cant find anywhere my 6 shorts cuts under exercise are Run, Bike, Swim, Treadmill, Weights, Interval Timer but no walk how can I get that. any help much appreciated as im loosing the will to live. overwise a very expensive pedometer.
Cheers Paul (Disco Dude)
Best Answer01-22-2019 07:27
01-22-2019 07:27
01-22-2019 09:01
01-22-2019 09:01
Hi I will try that as well do you have walk in your short cuts under exercise if so how do you get that. Cheers.
Best Answer01-22-2019 09:23
01-22-2019 09:23
Great to know that it's all working for you now, @Reedee! ![]()
Welcome @DiscoDude! You can add Walk to your shortcuts from the Fitbit app.
In Fitbit app tap on the Charge 3 icon in the top right corner, scroll down to Exercise Shortcuts - tap on it. There will be 6 shortcuts that are set by default - you need to remove one or few that you don't need in order to add Walk. Swipe to the left to remove shortcut(s), then a plus edit button will appear in the top right corner - tap on it. Select Walk (and any other shortcuts you might use) and click 'Add to Charge 3'. You can rearrange shortcuts to appear on your tracker in certain order.
To track an exercise, swipe to the left on your clock face, tap exercise, swipe to the left again to go through the list of shortcuts. Tap on an exercise you want to track. You can also manage additional settings from Charge 3: when on a specific shortcut, swipe up to see adjustable options.
Please, let us know if you have any questions!!!
01-22-2019 12:28
01-22-2019 12:28
Thank you so much I now have walk in exercises and will copy your advice that you gave ReeDee about mapping then all will be good. Must thank you again.
01-22-2019 12:45
01-22-2019 12:45
@DiscoDude, you bet! Please, don't hesitate to let us know if you have any other questions! ![]()
Best Answer03-07-2019 18:37
03-07-2019 18:37
@RiseAndShine How do you switch the Charge 3 to automatically track walking?
Also, is there a way that your walks show up on a map? I can’t find this on menus, and wondering if it is an option or feature.
Thanks!!
Best Answer03-07-2019 22:38
03-07-2019 22:38
Hi @javapop, autorecognition for walking is enabled by default unless you turned it on. However, for auto-recognition activity should continue for min set time (15+ min by default). You can change it down to 10+ min. To do so, in Fitbit app tap on the account settings (rectangular ion in the top right corner), then scroll down to Exercise, tap on it and adjust time as needed for different activities.
In order to track walking with GPS, you have to add walk to your tracker as one of the exercise shortcuts (if you already have it as one of the shortcuts, then you can skip this step). To do so, in Fitbit app tap on the Charge 3 icon in the top right corner, then scroll down to Exercise Shortcuts, tap on it - you'll see a list of 6 shortcuts that can be used for manual tracking right from your tracker. Remove one or few of them (swipe to the left). Once there're less than 6 shortcuts, the plus edit sign will appear in the top right corner - tap on it to select Walk and any other type of activity. You can rearrange shortcuts to appear them in certain order on your Charge 3. Sync the tracker - now you should have Walk (and other added activity) on your tracker.
To track walk with GPS, swipe once to the left, tap on Exercise, swipe to the left again to go through available shortcuts till you see Walk. First swipe up - you'll see an option to track with GPS, make sure it's set to on. Then tap on Walk to start tracking. Tap on start - the tracker will be connecting to your phone GPS. Once connected, tap on start again to start the exercise tracking. Once you're done with the walk - push button on the left side of the tracker: one push - exercise will be paused; second push - you'll see 'finish' option. Tap on it to stop tracking. Then sync your tracker with the phone to see the map of your walking route and all available stats.
You may find a lot more information in the help article on exercise tracking
Best Answer03-22-2019 07:54
03-22-2019 07:54
I've just got my charge 3 to replace the 2, and despite all your advice, I've still got no map Any other suggestions, please?
