05-04-2021
10:19
05:29
WilsonFitbit
05-04-2021
10:19
05:29
WilsonFitbit
Hello,
my interval timer on my charge 3 has stopped working. I have done a reset on the Fitbit, I have resynced the fit bit and the app.
any other suggestions?
Hello @Hilary3. Welcome to the community forums!
Thank you for the detailed information and for the troubleshooting steps you've followed. Please make sure that Sleep mode isn't on, when this setting is activated, notifications don't cause the tracker to vibrate or the screen to turn on, the screen's brightness is set to dim and turning your wrist won't cause the tracker's screen to turn on.
If that is not the case, I suggest performing a long restart. A long restart is different than the basic restart and you can perform this, by following the steps here:
Hope this helps.
