10-20-2018
11:21
15:06
10-20-2018
11:21
15:06
I used my new Fitbit yesterday swimming for the first time swimming 2400 metres freestyle with one stop for less than a minute.....it took 54 mins.
However the stats showed I had swam only 1600 meters and it took 67 mins!
Moderator Edit: Updated Subject for Clarity
Best AnswerI have an HR Inspire. It never records lengths correctly although usually only 2 or 3 lengths out (but today 10 lengths out). I know for sure that it is the fitbit that’s wrong as it will record an uneven number of lengths when I have swum an even number. I have tried making sure I tap end of pool with hand wearing fit bit - which slows me down). I’ve restarted it as well. Pleas advise what you are going to do about this. I especially bought this model as my exercise (other than walking) is swimming
Best Answerdefinitely question sleep stats. I seem to spend half the night awake according to fitbit, rarely have REM sleep and virtually no deep sleep. Lots of light sleep thoguh. I should be a zombie.....
Best AnswerExactly. Fitbit doesn’t care because the devices are still wildly popular. Not only does my Fitbit 3 not record swims correctly, it is also wildly inaccurate on bike rides. (Bike one way 100 calories, bike home exact same route and 300 calories! - can’t be right). Waste of money for anything other than steps in my opinion.
Best AnswerI have HR Inspire and it has exactly same problems. Sleep tracking I am sure can’t be right. It says I fall back to sleep when I lie in bed (awake) before getting up. I supposedly have very little REM or deep sleep (sometimes none of either) but am awake about 1 1/2 hrs during the night.
I do use the exercise/ swim tile but it never records laps correctly and like others my fitbit claims I burn only 4 calories every minute when I swim crawl quite vigorously.
Best AnswerYes mine says that I swim more lengths than I do, 45 when I swim 40 in a 50 m pool. But it does not record kicking with a kick board and it does not record if you stand at the end of the pool for more than 2 minutes. So I guess that's why it is inaccurate.
Best AnswerI found a YouTube video that says to do a reset not a factory reset but put it in the charger then hold down the power button while it's in the charger till you see the :-). I did this and mine is working perfectly now
Best AnswerThis looks like it's a very common problem. I'm having it myself Fitbit product support don't help at all (you have to call through the Fitbit app and that cuts out, live chat is a boy, and the actual people just give you the same list of things that don't apply). Steer well clear.
