03-31-2019
08:35
11:10
03-31-2019
08:35
11:10
Over time the brighness lowers. This seems to be an software issue because I can trick it into giving me a normal brighness when I fail to keep the fb connected while changing the clockface.
04-01-2019 04:21 - edited 04-01-2019 04:22
Hello @GJBerends, thanks for stopping by! On Charge 3, you can manage basic settings including brightness, heart rate, and button sensitivity directly on your tracker. Open the Settings app and tap a setting to adjust it (Brightness can be adjusted between "Auto", "Normal", and "Dim"). Swipe up to see the full list of settings.
I'd also recommend to restart your Charge 3 by following the steps at: How do I restart my Fitbit device?
Let me know if this helps, I'll be around!
Best Answer04-01-2019 06:55 - edited 04-01-2019 14:50
hi Marre
Yes I am familier with the options. In short every setting even normal becomes unreadable except at night.
I also tried the following:
- Change clock type
- Restarted the fitbit
- Reset the fitbit
Nothing seems to work and the fitbit works fine but the display is useless in the daytime.
I can trick the fb in the normal display brightness with changing the clocktype and while it is loading disconnect bt. It will work just fine with the brightness correct until I connect it with bt again and sync the fitbit data with my phone.
So for now I work around the problem but I hope Fitbit will help me with a solution. Because I want to see my steps and time during the daytime and sync it to get my messages on my fitbit. This is now impossible.
04-04-2019 13:02 - edited 06-14-2023 03:34
Hello there @GJBerends, thanks for coming back and for letting me know what you've tried.
I was about to create a support case on you behalf, but I saw that you got in touch with our Support Team after posting here. Please check your inbox, our team is waiting for your response. Next steps were sent to you.
Best Answer10-15-2020 09:51
10-15-2020 09:51
How do I get to the settings screen on the fitbit Charge 3?
Best Answer10-15-2020 10:39
10-15-2020 10:39
Same problem. I did a complete reset. Can hardly see the screen. I did sign up for 3 free months of premium. What a waste. Can't even see the screen. A lot of folks have the same problem. I'd like to wear it but even the time seems to be very dim. Any ideas - the ones from fitbit seem useless?
07-14-2022 20:27
07-14-2022 20:27
Is that a trick to lead us buy a new one?
Or a bad algorithm to conserve battery.
But why would that be adjusted by the app?
I have the same symptoms.
Those batteries are supposed to operate almost at full capacity for a 1000 charges. Charging it once a week it barely reached 150 charges for the 2.5 years I own it.
07-20-2022 15:47
07-20-2022 15:47
This is what I've come to believe. My Charge 3 is a few years old now but the screen is super dim. Best guess is it's being intentionally dimmed because of age so that I buy a new one
