02-15-2019
01:21
11:25
02-15-2019
01:21
11:25
I've been wearing my chargec3 since Christmas & the screen has been fine. But yesterday I noticed it was much dimmer & I was struggling to read the screen. I checked the settings, if I changed it to Auto it was impossible to see. I have performed an 8 sec restart & still no joy.......
02-16-2019 07:24
02-16-2019 07:24
Welcome on board @Dodos69, it's nice to see you around here! Thanks for taking the time to restart your Charge 3. Nice way to go!
Since the restart did not work, I'd recommend to restart Charge 3 using the 15-second method:
If this doesn't work either, since your Charge 3 is still syncing please try changing your clock face (since this process needs to be done in the Fitbit app) and let me know if the screen brightness is back.
Looking forward to your reply!
02-16-2019
13:53
07:48
02-16-2019
13:53
07:48
I have tried the 15 second reset & the screen brightness dosnt change. I cannot change the clock face because it now isn't syncing.
Can you help pls?Debbie
Update: Hi I have completed the 15 second re-set & I have changed the clock face. The screen is still dim.
02-18-2019 07:52
02-18-2019 07:52
Thanks for getting back @Dodos69 and for letting me know the outcome! I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps.
Point me out if there's anything else I can do for you in the meantime.
04-10-2019 13:18
04-10-2019 13:18
I have the same issue with my charge 3 and am now at the point where im not wearing it as i cant read the screen when its bright/daylight. I have adjusted the settings but still rubbish. Been with Fitbit for a number of years and have to say i am really unhappy and considering leaving altogether now.
Any advice on how to improve the brightness?
07-02-2019 17:08
07-02-2019 17:08
I'm having the same problem with my Charge 3. Anything I do to reset / restart, the screen is so dim I cant see it and it wont stay on for longer than 2 seconds
07-02-2019 23:05
07-02-2019 23:05
This seems to be a common problem, after 8 months of use my screen has gone very dim.
07-14-2019 16:28
07-14-2019 16:28
I've tried this 4 times & can't get the progress bar to complete more than 3 of the 7 vibrations... any advice?
07-15-2019 03:31
07-15-2019 03:31
None of the solutions work, the screen on my Charge 3 cannot be read, it's too dim.
How do I return it?
05-22-2020 10:26
05-22-2020 10:26
I’m having the same problem as everyone else. I got it in Jan (I think) and it was fine until a couple weeks ago. Now, in natural light, it’s completely useless. Inside, it’s barely visible. Switching between brightness settings hasn’t helped, at all, and neither have my attempts to perform the restarts you outlined. Please advise.
05-22-2020 11:59
05-22-2020 11:59
06-11-2020 10:50
06-11-2020 10:50
This is a very well known issue for Charge 3. I contacted customer support and rep said 'higher team' is working on this issue to resolve. I have used Fibit since the first generation and re-purchased 3 different Fitbits when they introduced newer devices. Now they said, because my device warranty expires they will offer 25% discount. The discounted price of Charge 3 is the same price that I can buy from Amazon. What does the disount mean? Or they can offer 40% discount for Versa Lite which is less popular one.
What a great service...
07-15-2020 23:17
07-15-2020 23:17
I am very angry. For this problem I changed two Fitbit charge 2 a few years ago and now I have the same problem with model 3?
07-16-2020 00:32
07-16-2020 00:32
Ik kan ook mijn horloge niet meer lezen ineens. Ik heb de 15 sec gedaan maar er gebeurd niks. Ook de wijzerplaat veranderd maar ook niks. Je het weinig aan een horloge als je er niks vanaf kan lezen
Help me aub
09-06-2020 09:02
09-06-2020 09:02
The only solution is to insist on a replacement. None of the proposed solutions from Fitbit work to improve screen brightness.
09-06-2020 10:12
09-06-2020 10:12
It should be a "Product Recall" which so many customers faces the same issue.
09-06-2020 11:53
09-06-2020 11:53
I agree 100% however I have to watch regarding things like this they will remove a post..🙄
09-06-2020 11:55
09-06-2020 11:55
Oh they did offer 35% off however only on certain items 🙄
09-06-2020 22:54
09-06-2020 22:54
50% at least
