06-24-2021
01:58
05:05
WilsonFitbit
06-24-2021
01:58
05:05
WilsonFitbit
It’s bothering me more and more that I
A. Cannot see my display in the summer (in bright light)
B. When the alert of an appointment happens, I can read the time, but not what it is…
anyone else problems…
Moderator edit: subject for clarity/label
06-24-2021 02:20
06-24-2021 02:20
Hi, @Me_Lizzy , there is a setting on the Charge 3 to allow you to adjust the brightness. Have you tried changing that? From the main, clock screen swipe left until you come to “settings”. Tap settings, and then tapping on “brightness” will toggle you from “normal” to “auto” to “dim”. Auto will adjust the brightness depending on the light around you, but I usually prefer mine on “normal”.
Having said that, I find that the colour screens are a little easier to read in bright sunlight. The new Fitbit Luxe has a colour screen and you might find this works better for you if you do decide to change to a different model.
Welcome to the forums!
04:05
05:10
WilsonFitbit
06-24-2021
04:05
05:10
WilsonFitbit
Yes, thought that was the issue….. really getting my mind now on saving for an apple watch…if I have to invest in another device to see the time properly 😞
Moderator edit: word choice
Best Answer06-24-2021 05:21
06-24-2021 05:21
Hello @Me_Lizzy. Welcome to the community forums. @Julia_G Nice to see you around and thanks for your input.
I'm sorry for the experience and thank you for the information. Adding to Julia_G's post, sometimes the brightness can be affected if your tracker goes into Sleep Mode. When the sleep mode setting is on:
But if this is not the case, I recommend contacting our Support Team for further assistance. Note that you can contact them through chat or over the phone, but phone wait times are longer than normal, so I recommend initiating a chat. Click here to get connected.
See you around.
