04-05-2019
00:18
11:10
04-05-2019
00:18
11:10
Hii
Charge 3 have some issues with WhatsApp notifications.
Notifications that I read in the phone doesn't disappear from charge 3 automatically.
If I receive messages from group in WhatsApp, I see in the notifications the same way as private messages (the group name doesn't appear in charge 3)
When I'm far from my phone, charge 3 might vibrate twice (as if I got 2 messages), when I get a message.
(and it might also duplicate some messages)
I hope you'll fix this bugs, it is annoying.
Thank you
04-06-2019 04:53
04-06-2019 04:53
Hello @Sportl33t, it's nice to see you around!
I'd recommend to take a look: How do I get notifications from my phone on my Fitbit device? to get all the information about how your notifications work on your Charge 3.
Let me know if you have any further questions. I'll be around!
Best Answer04-06-2019 06:13
04-06-2019 06:13
Thank you for your response.
But it didn't answer my questions.
I do receive all the notifications I want from the phone, but there are bugs in the way Charge 3 display those notifications (as I described in the previous post).
Best Answer04-08-2019 06:09 - edited 04-08-2019 06:13
Hi @Sportl33t, thanks for coming back and for clarifying your post previous post.
I'd recommend restarting your Fitbit Charge 3 by following these steps. Also, please try logging out and logging back into your Fitbit app.
If the notifications from WhatsApp are still not working properly, please try setting up the notifications again:
In regards to the group notifications, you should receive the name of the person who is sending the message follows by @ and the name of the group. If the name of the person who is sending the message is too long, that would be a reason why you're not seeing the name of the group.
Let me know if the steps work. I'll be around!
Best Answer04-10-2019 10:45
04-10-2019 10:45
I did all the steps as you mentioned.
But it still doesn't work.
What else could it be?
(my WhatsApp messages are in Hebrew)
Best Answer04-11-2019 08:52 - edited 04-11-2019 08:53
Hey @Sportl33t! After the last update on Charge 3 Hebrew notifications are supported. Currently, it's only available on Charge 3. It is just the first step to fully supporting Hebrew notifications. We are aware of limitations and issues, like messaging in reverse order.
If you clear a notification from your device, the notification is removed from your phone's notification center. If you clear a notification from your phone, the notification is removed from your device.
If your device is not clearing the notifications after you clear them on your phone, I'd recommend restarting your Charge 3 by following these steps. The restart should also work for the duplicate notifications.
Give this a go and let me know the outcome.
Best Answer04-13-2019 04:21
04-13-2019 04:21
I tried all the solutions for that, but it doesn't show the group name, and the name is not too long.
Best Answer04-13-2019 08:02 - edited 04-13-2019 08:03
Hello @Sportl33t, thanks for trying the suggestions recommended! As mentioned, you should receive the name of the person who is sending the message at the beginning, follows by @ and the name of the group. If the name of the person who is sending the message is too long, that would be a reason why you're not seeing the name of the group.
If the name of the group is not too long, but the sender is, that would be the reason why the name of the group doesn't show or shows incomplete.
Hope this clarifies your inquiry. Let me know if you need further assistance.
Best Answer01-01-2020 08:11
01-01-2020 08:11
Can you define "too long" as I'm having the same issue as well.
